Question about Air Tools & Compressors
Joy 185 john deere diesel air compressor start up good when in use looseing pressure after warm motor temp at 200 degree looking for manual
1986 model joy 185 jd diesel portable
2 Suggested Answers
compman66
  • 169 Answers
SOURCE: 1989 Ingersoll Rand 185 diesel compressor shuts down under load
most have safety shut downs built in, on the compressor side you will have a high discharge temp shut down, usually set to shut down @ 230 degrees F. normal temp should be @ 180F if it is running hot first check oil level on the compressor, and that the radiator is clean. some machines will have a thermostat that will only allow oil flow to go to the radiator after it comes up to about 150 degrees F. you really need to have a manual on the machine to see what other safety's it may have on the compressor and engine side as well.
Posted on Jan 09, 2010
Testimonial: "Thank you very much for responding. It was a little low on coolant. The comp. oil level was fine. I changed the fuel filter and the prob is gone"
John deere 332e skid steer loader
I would change hyd. fllter. Clean the hyd. screen
Jun 23, 2016 | John Deere Garden
JD 1630 turns over but won't start
John Deere 3179DL-01
diesel
3-cylinder
liquid-cooled
179 ci [2.9 L]
What is the Temp. in degrees outside. if below 35 degrees it will
be a problem. Some tractors are cold natured and a diesel needs
plenty of cranking amps to start. Have you tried either ?
If you do try either, crank the engine before you squirt it into the breather, and only a small amount. Either is hard on engines
this is why you use it sparingly.
May 27, 2014 | Peg Perego John Deere Farm Tractor and...
Where is oil cooler
Hi not totally familiar with this compressor but the oil cooler will be in front of the air intake vents with the cooling fan behind it
Mar 07, 2014 | Ingersoll Rand P185WJD Platinum Series Air...
I have a 175 pull behind IR compressor. When trying to set the high Idle I open the valve so that it is reading 100psi, the motor trys to throtle up but it seems under to much of a load. also when it drops...
100 psi is around the pressure that the engine goes back to idle
it should start to go to fast rpm when the pressure drops to around 75 psi
if it is trying to increase rpm at 100 psi , the engine is under load and that is your problem
Dec 19, 2017 | Ingersoll Rand P185WJD Platinum Series Air...
Hi. My company has a Sullair 185 diesel air compressor that will run for approx. 4 hours than shut down. The indicator lamps flash "4" flashes and the unit will start right up. We do not have a...
Take note of page 24 in this PDF
http://www.scribd.com/doc/45811151/Manual-de-Mantenimiento-Sullair-185
It states the 4 flashes indicates low engine speed it is part of the SSAM system.
Jul 19, 2011 | Garden
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Jan 08, 2010 | Air Tools & Compressors
Air conditioner in 1999 mercury tracer won't work. It's not the compressor nor does it have a leak. what could be the problem?
the tracer is the same as the ESCORT, right?? TRY THIS--I WORK ON PLENTY OF ESCORTS--LOOK UNDER THE AIR CLEANER/CONE ASSEMBLY--THERE WILL BE A BLACK METAL BOX(FULL OF RELAYS) ONE OF WHICH IS THE A/C RELAY--TRY TAPPING ON IT WITH A LONG SCREWDRIVER OR SOMETHING SIMILAR WHILE U HAVE THE A/C ON. IF THE A/C SUDDENLY STARTS WORKING U NEED TO GET A NEW RELAY BOX(I THINK ITS CALLED A GEM MODULE) i do have a question- does the blower motor work?? how do u know the compressor is good??do you have 12 volts going to it??? this relay box is pretty common to go bad--u have to remove the air cleaner in order to get to it.get back to me.
Sep 07, 2009 | 1999 Mercury Tracer
1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Apr 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
29 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
