Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio Washer F1
I too had a F1 control problem with my cabrio and after being told the problem did not involve my model number WTW6600SB2 I still demanded they cover the labor and parts at 100%. They did finally agree to pay for the entire repair. Don't give up.
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$&^#$@%
Posted on Sep 20, 2010
My whirlpool CABRIO washer is constantly giving me F1. I can hit the cancel button 4 different times and it will finally work. The F1 comes up on almost types of washing.
f1 code on cabrio washer indicate control board sensing a pressure transducer signal water pressure sensor signal (water level pressure sensor signal taht is out range .u might have a problem with the hose that connect from washer tub to pressure switch . so if you dont know how to check it you migth want call a appliance repair tech are you can put your model number in google an they can show you a video on how to repair your washer. ok
Mar 22, 2018 | Whirlpool Washing Machines
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Need trouble shooting manual wtw6600sb2
    You can get the owner's manual here:
    http://www.appliancepartspros.com/parts-for-whirlpool-wtw6600sb2.html
    Page 20 has a troubleshooting section.
    YouTube is now a great resource for a Whirlpool Cabrio owner. Just type it in to the search bar at YouTube and watch step by step procedures in many instances. Some are just advertising but you'll figure out how to spot the ones you're interested in. Let me know if i can help.
    Jan 13, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
    Why does F1 code show and the washer stop on my whirlpool cabrio
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Jul 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 ERROR CABRIO MODEL WTW6400SW0 SER# CT2170433
    Please see the following Whirlpool installation and maintenance PDF on Cabrio washers. An F1 relates to a "primary control failure".
    It also has a very extensive troubleshooting section.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
    Oct 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 on Cabrio washer, it still works though. Is this a problem?
    i just called customer service on our this morning and they are going to fix and pay parts and labor, they know about this problem, good luck, the phone number, model and serial number are located under the lid
    Jul 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Cabrio Whirlpool WTW6600SWO
    you have a cabrio not a calypso..1st calypso did not display f1 codes BUT a cabrio does indicating bad control module.. changed 1 last week same issue..i'm sure if you go to sears .com click parts link type in your model number it will come up a cabrio..let me know how it turns out
    Nov 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    167 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
