Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony kv32fs16 problem
The tv turns itself off with the stand light blinking four times.
  • 5 more comments
  • Anonymous Apr 13, 2008
    stand by blinking
  • Anonymous Jun 12, 2008
    I have the exact same problem. But have yet to find a solution. Any help would be great
  • paul5555 Jul 05, 2008
    kv 27v65 turns on and immediatly turns off. small red blinking light flashes 4 times then pauses and repeats itself indefinitely
  • bmann Sep 21, 2008
    Blinks Seven Times and repeats itself.
  • PSUMikey Oct 13, 2008
    Same issue on a 32 inch.
  • mmace0025 Oct 17, 2008
    Tv has turned off and will not turn back on. There is a red blicking light.
  • fdidominick Oct 20, 2008
    I have a similar problem. My Sony KV32fs16 initially turns itself off after about 30 minutes. If I try turning on again at that point, it will only stay on for a few minutes. Every subsequent turn on will last less and eventually turn itself off after a few seconds.
No sound tries to come on shuts right back down
Posted on Dec 28, 2007
Tv turns itself off with the stand light blinkingfour times
Posted on Dec 16, 2007
You could have a bad pic tube can you still here sound do you see good dark green, blue, red if not then bad pic tube
Posted on Nov 02, 2007
    Problem Solver:
  • 15 Answers
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sony kv32fs16 problem - sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Jan 16, 2009
I have a sony trinitron 27 in. model KV-27S45 1998 it will not turn on and the stand by timer is flasing 4 times dont know what to do
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
Mar 25, 2011 | Sony KV-27S45 27" TV
SONY KP-53S75 tv problem
the four times is a code for what part of your tv is having issues. A Qualified Sony Service Shop should be able to give you an idea and or cost of what the repair is. 'Call around'
1) My thoughts is that there is either an HOT, 'High Output Transistor' that has gone out or maybe even a flyback that sends the High voltage to your 3 crts.
Blessings,
A/V Media Tech Guy
Nov 27, 2009 | Sony KP-61S75 TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Stand by led blink 4 times
my tv is FD Trinitron WEGA KV-HA21. when i press the power button it starts but after about three secounds it trips to stand-by and starts blinking four quick succession at intervals
Jul 20, 2008 | Televison & Video
Sony Trinitron KV32FS16==> Need to push pwr button multiple times
after it fails how many times does the red LED blink? check the board very closely for any cracked solder. and then check the main regulators. also look to see if you have any physically bad capacitors, they might look like they are exploding on the top.
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
Jan 03, 2008 | Sony KV-32S26 32" TV
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
No picture and no sound just a blinking stand by light on front of my sony kdl40s2000 lcd tv
I have a Sony KDL40S2000 and three months out of manufacturer warranty my TV made a clicking noise similar to feedback in a bad sound system and went to black screen. The error was not recoverable and four blinking lights were seen by a technician. I bought the extended warranty from my store, so I was covered. After one month in the shop, the technician brought my TV back today and told me the panel was replaced which would have cost me 1000 dollars if I wasn't covered by the store warranty. I read on another site the four flashing lights can mean a bad inverter. I don't know enough about TVs to tell you if the panel and inverter are one in the same, I just know you need to get it repared if you get four blinking lights at a huge cost!
Dec 18, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
483 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
