Home | GE | 24 in. Profile PDW7800 Built-in Dishwasher | Dishwasher will not fil...
GE 24 in. Profile PDW7800 Built-in Dishwasher
Problem for GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher will not fill up with water
By d_scott_5 on Jun 18, 2009
I have a PDW7800 GE Profile dishwasher. I found the breaker kicked one afternoon. After that no water would come into the machine. I replaced the inlet valve/solenoid and the control. Still no water - $150 invested and still doesn't work. Any ideas?
Comments:
Jun 18, 2009
- How do you check it???
Jun 18, 2009
- Removed the switch (hooked to the float) Not much to click - Just a flat piece of contact material that stays done on the switch. I jumpered the plug and it blew the breaker. Is the switch bad or do I have a bigger problem?
Jun 19, 2009
- Yes - I unplugged the switch and jumpered the plug
Jun 19, 2009
- Just replacing the switch won't help then right? Where else could the problem be??
Jun 19, 2009
- The coil in the bottom? How do you check it?
Jun 19, 2009
- That will take some work - the unit is still installed. I will have to pull it out. May not get to it until this weekend. I am looking for 0 ohm's correct?
Jun 19, 2009
- Thanks for all the help - much appreciated. Have a great weekend!
Solution #1
posted on Jun 18, 2009
Not Rated)
despentiado
Rank: Guru
Rating: 88%, 63 votes
did you chek the level micro switch thats in serie with the intlet valve
Comments:
Jun 18, 2009
- follow the wires connecting to the intlet valve one goes to a micro switche not far away from the valve just check on and off , see if it clicks and if not just connect the two wires together and try that way
Jun 18, 2009
- you jumped the switch wires rigth not the intlet ones
Jun 19, 2009
- ok so you have a bad switch and something else is wrong to
Jun 19, 2009
- check the heater is shorted 4 sure
Jun 19, 2009
- two wires at the back of unit disconnect one wire and measure how many ohms you have
Jun 19, 2009
- o ohms is shorted needs replacement
good luck 4 more help just post
Jun 19, 2009
- your welcome anytime
Was this helpful?
Yes
No
Popular Solutions for GE 24 in. Profile PDW7800
Questions and Unsolved Problems for GE 24 in. Profile PDW7800
Do you recommend GE 24 in. Profile PDW7800 Built-in Dishwasher?
Answer
Answer
my dishwasher is stopping and flashing the normal light and beeping. when reset does same thing
Answer
My dishes have a gritty residue on them. I am using Electrasol Advanced. The dishwasher is GE... (More)
Answer
installing an end cap # wd12x344 on a ge profile dishwasher
Answer
I have a GE Profile dishwasher w/automatic dispenser. Glasses are foggy, cups are not clean inside,... (More)
Answer
I just replaced the control module of a GE Profile modle PDW7880G00SS and not the control panel... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 24 in. Profile PDW7800...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
