Question about GTCO CalComp TechJET 5536GA InkJet Printer
Techjet designer720 servo internal error - GTCO CalComp TechJET 5536GA InkJet Printer
My Book 1Tb not visible in the system ["Status code = 06 (Failed servo an/or seek test element)]
First,Your first sign was the "Failed servo an/or seek test element" mistake,the second was taking it from the plastic casing and plugging it into your pc. The servo is bad! you are better off replacing the drive.You pretty much can write off any data you had on it if the servo is shot.
Feb 15, 2014 | Western Digital My Book Essential Edition...
Servo light
You have an internal problem in the amplifier of the sub woofer box. You need to take it in to be checked at a service center, there are no quick fixes for them. Sorry,
Dave
Jul 01, 2008 | Infinity BASSLINK Car Subwoofer
Hi. The Sportasrt T680 Treadmill shows Error 2_1. Does anybody know, what should I check in the AC Servo Driver? The IGBT bridge is okay. Any other? Thanks.
hi,
The primary reason for E2-1 is that the drive board detects IGBT over current signal
Check the folowing.
A. Re-start the unit.
B. Inspect whether the servo motor wires are connected properly to the motor.
C. Replace the drive board.
D. Inspect the servo motor windings for a break. If so
E. Replace the servo motor
Aug 28, 2011 | Exercise & Fitness
HI THE SELF DIAGNOSIS ON MY R6 2006 AS COME UP WITH ERROR CODE 18 COULD YOU TELL ME WHAT THIS CHEERS STU
Your EXUP is the butterfly / valve that is in-line between your center muffler/Cat and the stock exhaust can. It is controlled by cables from a servo motor under the tail / behind the rear shock.
The EXUP errors (17 and 18) are because:
1. you removed your EXUP servo and/or valve when you installed your exhaust.
2. your EXUP valve is stuck / cables are seized up
3. your wiring harness is disconnected from the servo motor.
Jul 15, 2011 | Yamaha NC 110 Motorcycles
Error 91-455 show in sony dsr-1800p dvcam get a service manualfor this model. pleas.
Error 91:455 i means: Communication error between servo main and servo sub microprocessors.Dose it take the tape in?if can tell me more.mail me in Pemring@gmail.com
Nov 26, 2010 | Sony DSR-1800 DV/Mini DV VCR
Our gta san andreas have an error
What exactly is the error your seeing on your tv?
Mar 26, 2010 | GTCO CalComp TechJET 5536GA InkJet Printer
We have a Calcomp Techjet 5424 printer. We got it
I have the same plotter and use canon BC-02 cartridges they work fine although they can be difficult to find, have you tried refilling the empty cartridge yourself it's easy piezy.
Aug 27, 2009 | GTCO CalComp TechJET 5536GA InkJet Printer
Ac servo drive Errors
seus burro
Jun 17, 2008 | GPS
Error code C:31:70
this is servo IC problem.
May 31, 2007 | Sony DSR-45 Mini DV VCR
GTCO CalComp TechJET 5536GA InkJet Printer Logo
55 people viewed this question
Top GTCO Office Equipment & Supplies Experts
jasbo
jasbo
Are you a GTCO Office Equipment and Supply Expert? Answer questions, earn points and help others
