Question about Tablets & eReaders
Proscan plt1066 tablet driver issue
I turn on tablet. it goes thru the blue screen and android "person", then it stalls on the "android" word screen. it just lights up from left to right. It doesn't go any farther.
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
  • 17 Answers
SOURCE: looking for driver for imito am801 8" tablet for Android 2.3
.I know a wholesale online store. you can buy android 2.3 that have good quality and reasonable price will make you satisfied,.hope you can find the suitble that you need.good luck.
Posted on Apr 26, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
jaretheil
  • 9 Answers
SOURCE: I have an android tablet, YouTube works but when I
If you updated your operating system you may need to go and turn the auto rotate back on under options.
Posted on Nov 04, 2013
ishanjain28
  • 21 Answers
SOURCE: Tablet wont boot
MaybeMay
Posted on Jan 07, 2014
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
How to pair my ilive blue tooth wireless head phones with a proscan tablet
Open the blue tooth menu on your tablet (usually -> Settings -> Bluetooth)
Turn on your head set. Usually there is a pairing button option, on your set, you need to turn the headset off, then turn it back on but hold the power button for 8 seconds until they will flash red/blue.
You should be able to find your headset then on your device.
How to pair bluetooth headphones to your phone
Nov 08, 2015 | Proscan 10.1-Inch Internet Tablet,...
Can i get a replacement power charger fot proscan plt1066 tablet
check on ebay website they deliver it with no problem using postal addres within a week or two.
Aug 19, 2014 | Tablets & eReaders
Does a proscan tablet have a rear camera
Depends on the model.
The PLT1066 has a front and rear camera.
Aug 13, 2014 | Proscan 10.1-Inch Internet Tablet,...
Why my proscan wont turn on ?
If the battery is weak, the tablet won't turn ON. Contact the authorized service center. http://electronicshelponline.blogspot.com/
Jun 09, 2014 | Proscan 7-Inch Android Internet Tablet,...
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Loads splash screen only
Have you tried the pinhole reset?
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
My proscan will not turn on and it is charged
Your tablet may either be so low on power that it is non functional, or you may have to reset the tablet.
Dec 21, 2013 | Proscan 10.1-Inch Internet Tablet,...
Tablets & eReaders Logo
353 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
