Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Flashing light my tv won't turn and I have constant flashing green light
  • 1 more comment
  • mike mits Jan 17, 2009
    Green constantly flashes on front of WS65813. HV power is present past fuse on WS 828132800085M board and passes to WS65813500099P board. I would think the transformer to the tubes is bad, How much is that board. Need to replace quickly with NFC championship and Super Bowl upcomming.
  • heinzkoebern Jan 29, 2009
    The green front LED flashes all time and I can't switch the TV. I pressed a paper clip in the little hole where it says System Reset for about 30 seconds but without any results. I just called a Mitsubishi authorized Repair shop and they told me that I had to unplug the TV for several hours and the try to rest the unit again. Is this a well-known problem with this Model WS 55813 55" Rear Projection HDTV Television?
  • jess819 Feb 06, 2009
    I have the same "green blinking light" issue...sounds like it's a common issue. Not many places are willing to make a 'house' call to diagnose the issue. Any suggestions?
The blogs on this subject are enormously helpful but you gotta be persistant to solve this TV problem because the fix may not be just the caps. I have a WS 65813, left the house for 3 months, came back to a blinking green light. Read Fixya and others and determined the fix is the caps on the DM board. Went to Radio Shack, got the caps, replaced them, plugged the TV in and now no light what so ever. In and out with the DM board 5 times before I called a local repair guy who told me to bring in the light box (chassis)..he said "I must have really done it.", meaning I'm way over my head and that's what I get for reading Fixya blogs and others. I swallowed my ego and decided to give him the light box chassis and $400 estimated. To take out the light box you have to remove the front panels. When I removed the glossy panel I noticed the cable connector to the power switch had separated, no doubt from the stress of sliding in and out the chassis to access the DM board (there is not much spare length in the cable feeding to the front panel). I reconnected it and voila! at least back to the blinking light..although still not fixed even with new caps. I read more blogs and saw there are three 4A SMT fuses on the underside of the DM PWB that someone suggested to look at. Got out the VOM, and there it was a bad fuse as open as the back side of my Mitsubishi. To see if it was the culprit and not having a replacement I soldered a small strand of wire across it, re installed the DM board now the 6th time and MADE SURE all connectors are back in place VOILA and it is fixed (temporarily) Super Bowl eve. I plan to get the right fuse and replace my temp fix. Lesson learned, you can mess things up trying to fix things so stay patient if you are a DIY're... you have to trial and error more since you are not the expert and are fixing things once. But it feels real nice saving $1,000. Now on to my charger on the boat.
Posted on Feb 01, 2009
    Genius:
  • 1,694 Answers
Bad DM module = replace or repair by skilled Mits tech only....
Research my solutions or comment, please..
Posted on Nov 04, 2007
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Flashing green light once constantly
Main system control IC fault. When replacing, Main system control & its Memory IC; both should be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 18, 2014 | Toshiba Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Televison & Video
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
Yellow power light will not turn green
It sounds like U have a bad box. This seems to be the most common problem with them, besides not picking up all the channels.
May 01, 2009 | Televison & Video
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Flashing Green Light TV will not turn on
Where do I send you the info with illustrations?
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
331 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
