Question about Beko Refrigerators
Fitting cupboard door to beko bl21 fridge
Door will not close when cupboard door fitted
SOURCE: Smeg Ice box leak
I don't know about those.
Posted on Sep 27, 2008
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
  • 166 Answers
SOURCE: How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
Posted on May 25, 2009
farfield
  • 462 Answers
SOURCE: removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Posted on Jun 27, 2009
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
Why won't my hinged cupboard door stay closed?
Depends on type of hinge, If it swings back open after you closed it then either the cupboard is not level (old style hinge)...
Or the spring inside hinge is bad/broken and not holding it closed. If the door opens back just a bit (1/2 inch or so) see if hinge has adjustable screws.
Oct 15, 2016 | Top Knobs Hardware & Accessories
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
Beko door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko WM5140W washing machine How to Replace Beko washing Machine Door Seal
Jun 27, 2012 | Beko WM5140W
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Fridge gives ice and water thru the door. The water line coming out of the bottom of the door is leaking. The line comes out from under the door with a couple inches of tubing that "plugs" into a connector...
That connector is known as a John Guest fitting, and they will sometimes leak. Make sure the tubing is firmly pushed into the fitting on both ends. If it still leaks, you will need to get a new John Guest fitting. Your local appliance parts supplier should have them, or they are readily available online. You are looking for a fitting that is 5/16 of an inch on both sides. If a new fitting dosen't solve the problem, your tubing may have a pinhole leak in it, and would need to be replaced.
Sep 29, 2010 | Refrigerators
Replaced door seal now door is difficult to close.
Sometimes, it is hard to close door after fitting a new seal.
Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
Try smearing the door glass with washing up liquid, this can help to close the door more easily
Please rate my solution.
Thankyou.
Feb 13, 2010 | Ariston Technologies Washing Machines
Water gathering on top of fridge like water droplets i have to dry it up every other day
Check to make sure that your seal is tightly fitting. Do this by taking a piece of paper and close the door on it near the seal around the door. You shouldn't be able to pull it out. If you can, replace the door seal. There's too much moisture from a bad seal. Hope this helps.
Jul 13, 2009 | Frigidaire Professional Series 24 in....
Fridge is running but won't get cold
if it have one compressor the gas in the system are low . but if it have 2 compressors the thermostat can be the problem
Jun 01, 2009 | Refrigerators
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Refrigerators Logo
Top Beko Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
