i have 3 dehumiifier- two of them works for about a minute then stops .i then turn off the unit and on again and it works for about a minute then stpos again and so on.one of the three units works fine-this same unit is older than the other two.Ironically the other two were hardly called to do any work at all before i noticed they were not working
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running....
(More)
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running. Kenmore model 580.54351 35 pint Basement is wet and not sure if this model is for basement temps but it works the same in warmer temps.
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change...
(More)
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change the %. It just beeps. the bucket full light flashes even though the bucket is empty. I usually set it on 3 hrs on/off. Have tried powering on/off, etc. Coils not iced up.
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect...
(More)
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect water
ran fine for a couple of weeks. emptied bucket several times. Then would not start for several days....
(More)
ran fine for a couple of weeks. emptied bucket several times. Then would not start for several days. Yesterday is started again. When I moved it to garage it will not start again. Bucket is all the way into the machine. I am wondering if the kill switch has a tendency to go out?
