Question about Polycom Lands Phones
Polycom blinking green lights - Polycom Lands Phones
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
I need to get the connector color code for a Polycom Soundstation conference phone.
From bottom of connector (not clip side)
Black
Brown
Red
Orange
Yellow
Green
Blue
White
Feb 08, 2011 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Polycom ViewStation H.323 Red Blinking Light
Are you able to move the camera using the remote?
If not, then you may have a hardware issue.
If yes, then try to connect to the Viewstation (web interface) using its IP from a Computer.
Let me know what happens
Jan 18, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Registration Failed
I solved this issue with our Polycom by following the following instructions via the link below.
Upgrade phones with following software:
CVM: Version 1.61
All SoundStation2Ws with software CVM version 1.61 are susceptible to this failure mechanism and must be updated. To upgrade the software, please download theSoundStation2W Software Upgrade application and follow the detailed Software Upgrade Instructions located on the SoundStation2W support page. This issue only impacts the CVM version number listed above.
Requirements:
1. USB cable for the Polycom wireless unit
2. Windows XP machine
3. Download the instructions
4. Download the Firmware Update
Dec 27, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Polycom soundstation Ex - no dial tone
Someone in our office recently damaged the RJ-45 cable for our Polycom Soundstation. Because the jack was damaged I could not determine the order of the cables. After a call to polycom, we found the pinout information we needed - so I thought I would share, in case anyone else finds themselves in a similar situation:
With the RJ-45 prong pointing down the wires, from left to right are:
  • Black
  • Brown
  • Red
  • Orange
  • Yellow
  • Green
  • Blue
  • White
Then Crimp and test. I got this information directly from Polycom for use with the Polycom Soundstation. This information was not easy to get. They originally told me they could not provide the information and I would have to buy a power adapter. This is not true, just trim the cable and follow the above instructions.
Sep 14, 2007 | Polycom PCY220016000001 SoundStation2...
Lands Phones Logo
64 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
