Question about Casio FX5800P Scientific Calculator
Casio fx5800p degree to radian - Casio FX5800P Scientific Calculator
  • 8 Answers
SOURCE: don't know how to change it from degrees to radian mode
if you press the |mode| button (at the top right of the calculator) until you see Deg Rad Gra on the screen (I believe 3 presses of the mode button) and just hit the number below the rad option on the display. This will permanently change it to radian mode until you repeat this step, or clear the memory.
There is also a way to change to radian mode for just one operation if you will be mostly using degrees for example
at the bottom there is a DRG> as a shifted function. I would just recommend changing it in the way I initially outlined as there is less room for error when making calculations.
Posted on May 06, 2009
  • 7993 Answers
SOURCE: HOW DO I CHANGE THE RADIANS MODE TO DEGREE MODE
Turn calculator ON.
If you do not see icons, press MENU.
Use arrows to highlight the RUN icon and press EXE
In RUN application press SHIFT and SETUP
Use Down Arrow to highlight the line Angle
Press F1 to select Deg and press EXE.
This action will return you to the RUN application (main calculator screen).
Hope it helps.
Posted on Nov 27, 2009
  • 7993 Answers
SOURCE: casio fx-300es---how to convert radians to degrees
You use the key combination [SHIFT][ANS] (DRG>).
If the default angle unit is degree
Type in the angle value in radian, say 1.2.
Press [SHIFT][ANS] (DRG>).
The screen displays 1: deg symbol, 2: a raised r for radian, and 3; a raised g (for grad).
1.2 [SHIFT][ANS] (DRG>) [2: raised r] .
The screen displays 1.2 with a raised r to the right of the 2.
Press [=].
The answer is 68.75493542
Posted on Dec 07, 2009
  • 7993 Answers
SOURCE: How do you switch between degree and radian mode
Press SHIFT MODE to access (SETUP)
Press 3:deg for degree OR
press 4:Rad for radian.
Posted on Apr 05, 2010
  • 7993 Answers
SOURCE: how the heck do you change a casio fx-9750II from radian to degre
  1. With calculator turned on, press [MENU] if you do not see icons.
  2. Use the navigation arrows to highlight [RUN-MAT] icon or press 1.
  3. In the Run-Mat screen press [SHIFT][MENU] to enter the (SETUP).
  4. Press the DownArrow 5 times to highlight the ANGLE option.
  5. Press [F1:Deg] to select degree.
  6. Press [SHIFT][EXIT] to (QUIT) the SetUp screen.
  7. Do your geometry ( I would say trigonometry).
Posted on Apr 08, 2010
How to change from degrees to radian mode casio fx-cg10
In Run>Mat screen press SHIFT MODE to enter the setup screen. Scroll down to the line Angle. Press F2:Rad to set angle unit to radian, See Screen capture below.
Jul 06, 2014 | Casio FX-300MS Calculator
My calculator is not computing sin^-1 or cos^-1 correctly, I put sin^-1(0.184) in and it came out with 10.60283... when I should be getting 1.39. HALP?
When the angle unit is in radians
sin^-1(0.184)=0.1850543940 radians
When angle unit is in degrees
sin^-1(0.185)=10.60283581
Your calculator is calculating the functions correctly)
In the following screen captures the sine of the values is calculated with the unit specified inside the formula (degree symbol and radian symbol are inserted to show you the unit). In the last calculation the value of the sine is practically 0.184
Remember that when angle is in radians, for very small angles (less than 10 degrees), sin(x) and tan (x) are about equal to the value of the angle in radians
Mar 25, 2014 | Casio FX-115ES Scientific Calculator
How do I switch between degrees and radians?
Press SHIFT MODE and then 3 for degrees or 4 for radians.
Nov 29, 2012 | Casio fx-115ES Plus Scientific Calculator
How to draw a trig function (y=sin(theta)) on a Casio 9750 gii
The variable theta is reserved for polar plots. So if you want to graph functions of the form y= expression, you must use the default variable x. Thus draw y=sin(X). Make sure your calculator is configured with the correct angle unit (degree or radian).
If you use degrees the window dimensions for x must cover an interval of 360 degrees, to have a full period. If angle unit is radian, then choose an x-interval between [-pi and pi] or between [0 and 2pi]
Sep 18, 2011 | Casio FX-9750GPlus Calculator
Why the value of sin in my calculator is incorrect? my calculator is casio fx 85ms
Check that your angle unit is the correct one. If your problem requires degrees make sure the calculator is set to degrees also. If radians then you should set radians.
Jul 16, 2011 | Casio FX85MS Scientific Calculator
How do i convert 45degrees into radians on my casio fx-83es calculator?
To convert from radians to degrees, multiply by pi and divide by 180.
Feb 19, 2011 | Casio FX-115ES Scientific Calculator
How to switch between radian mode and degree mode
Press SHIFT MODE then 3 for degree or 4 for radian.
Dec 04, 2010 | Casio FX-115ES Scientific Calculator
How do you switch between degree and radian mode on the fx-115 ES Casio calulator? Thanx
Apr 02, 2010 | Casio FX-115ES Scientific Calculator
Casio fx-300es---how to convert radians to degrees
Press [=].
Dec 02, 2009 | Casio fx-300ES Calculator
Casio FX5800P Scientific Calculator Logo
218 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
