Question about APC Smart-UPS XL 2200VA 120V (APCSU2200XLNET) UPS System
Overload problem Whenever I switch it on its goes to overload without any load on it.what is the problem and solution
    Champion:
  • 411 Answers
If there is an internal fan oil it's pivot or replace it.
If not circuit board is faulty. Time to buy new UPS. I have one like this that cannot be repaired.
Posted on Aug 20, 2014
jitenok
  • 151 Answers
SOURCE: APC UPS CS 500 (BK500EI)
If you can repair pcb then check overload protection section.There is some shortinng in components or ic could be demage.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 08, 2008
  • 25 Answers
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
Posted on Jul 11, 2009
  • 68 Answers
SOURCE: Overload LED lit, constant warning tone, no load
you may have to many things plugged into the ups, it is not good to plug a power bar into one of the outlets of one of these as you are OVERLOADING the device with more power than it can produce
Posted on Oct 24, 2009
  • 25 Answers
SOURCE: APC smart UPS
Check mosfet.
Posted on Mar 09, 2010
jaye_ellen
  • 591 Answers
SOURCE: hi my APC 1500VA smart UPS show overload
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
Posted on May 06, 2010
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Mar 11, 2015 | Aqua Pool & Spa
I have an old air compressor that I have replaced the motor magstart and pressure switch on the motor is a 220 / 240 volt 5 horsepower motor it also has a low pressure oil cutoff switch does anybody have a...
Control: L1-SS-P-O-OL-OL-M-L2 In series, L1 is line 1, SS is start/stop switch, P is pressure switch, O is oil switch, OL is overload contact, M is magnetic coil (solenoid), L2 is line 2.
The voltage of M must be rated for the control voltage, across the line voltage (240V) or of a control transformer voltage, e.g. 240v/24v. A control voltage would be wired across the line, to L1 and L2.
Power: L1-T1-OL-M1, L2-T2-OL-M2. Line one to Line 1 on contactor, T1 on contactor jumpered to OL (overload heater) and out the overload heater terminal M1 to the motor terminal 1. Same for line 2, Line 2 to L2 on contactor, T2 on contactor jumpered to OL (overload heater) and out the heater overload terminal to M2 motor terminal.
The heater overload relays needs to be chosen by the motor full load current, a chart is given with a motor starter on selecting heater size. If no chart is available, go 115% of the motor FLA (full load amps) to select a heater size. E.G. 25 FLA motor at 115% is 28.75a. Sorry, no schematic available now, draw your own from this info. If using 3 phase, add the third line as duplicating one other line1 or line 2
Mar 10, 2015 | Air Tools & Compressors
Do I need to lubricate the peg perego polaris 850 gold to keep from overloading?
peg perego has a known issue on these due to bad circuit board, contact them to get replacement
Jun 19, 2014 | Peg Perego Toys
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload prblem of inverter
PLEASE MAKE SURE THAT ALL THE LOAD CONNECTED TO THE INVERTER IS NOT MORE THAN ITS CAPACITY, BUT IF IT SHOWS OVERLOAD WITHOUT ANY LOAD CONNECTED TO IT MIT IS POSSIBLE THAT THE OVER LOAD CONTROL IS BAD
Nov 13, 2009 | Inverter Yaskawa F7 Drive
I am replacing the relay switch and overload switch for this kenmore frig/freezer. model 25358682890. the capacitor has two wires. one fits the overload component. do they both attach to this or does one...
your start device has 2 wires connect to it and the cap slides into it unless you have a relay and over load and in that case one wire goes to each
Dec 12, 2008 | Refrigerators
The boiler lights up for about 8 seconds then goes to lock out
what type of boiler is this? and do have you switched the chill water over from the chiller to the boiler??
Nov 04, 2008 | Heating & Cooling
Installing new over load relay
The line voltage goes to the overload and the neutral(and capacitor lines if it has one) goes to the relay.
Dec 05, 2007 | Whirlpool GS6NBEXR Side by Side...
APC Smart-UPS XL 2200VA 120V (APCSU2200XLNET) UPS System Logo
75 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
