Waeco fault code F05
When I turn on my waeco air con unit fault code F05 appears
koolbreezes
  • 540 Answers
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Posted on Aug 23, 2008
  • 68 Answers
SOURCE: I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Posted on Aug 03, 2009
SOURCE: Ecu-Maxx Marine Air-Con. Compressor Load Fault
Clean the filter on the water pump. It may be clogged. Even if there is just a little bit of gunk in there it can cause this error.
Posted on Jul 11, 2010
hvac1960
  • 2133 Answers
SOURCE: i have an celestial air
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Posted on Jan 22, 2011
hvac1960
  • 2133 Answers
SOURCE: LG B30AWY fault code ch
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Posted on Feb 07, 2011
I dont seem to have a power supply to my Waeco air con roof unit
Check breaker at main panel. Check breaker if applicable in disconne t on roof. If this is a pull out disconnect make sure it is installed the right side up. If no issues with high voltage you may have a blown fuse on the low voltage side. Turn power off at disconnect, open machine and look for a small,blade style, like one for a car, 5 amp fuse that may possibly be blown.
Jun 13, 2017 | Heating & Cooling
Mains adaptor for waeco cf50 has broken down (240 volt)
Have you tried getting in touch with an authorized service center?
Or Waeco Pacific Pty Ltd, 1 John Duncan Court Varsity Lakes QLD 4227 Australia Phone: (07) 5507 6000 Fax: (07) 5507 6001.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 22, 2008 | Refrigerators
Mobitronic user manuals
Fordern Sie weitere Informationen zur umfangreichen Produktpalette aus dem Hause
WAECO. Bestellen Sie einfach unsere Kataloge kostenlos und unverbindlich unter
der Internetadresse: www.waeco.de
http://www.waeco.com/tmp/900_serie_B_10S_08.pdf
Jul 29, 2012 | GPS
Waeco cf 40 portable refrigerator runs continuely
This is not an uncommon problem and you're probably experiencing a voltage drop between the battery
Dec 20, 2009 | Refrigerators
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
