Fault code F05 on my waeco air con unit - Heating & Cooling
5 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Posted on Aug 23, 2008
  • 68 Answers
SOURCE: I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Posted on Aug 03, 2009
SOURCE: Ecu-Maxx Marine Air-Con. Compressor Load Fault
Clean the filter on the water pump. It may be clogged. Even if there is just a little bit of gunk in there it can cause this error.
Posted on Jul 11, 2010
hvac1960
  • 2133 Answers
SOURCE: LG B30AWY fault code ch
Outdoor unit PCB EEPROM failure, try removing EEPROM and refitting if removable (possible contact fault), otherwise replace PCB if the EEPROM is non removable.
thanks.
Posted on Feb 07, 2011
I dont seem to have a power supply to my Waeco air con roof unit
Check breaker at main panel. Check breaker if applicable in disconne t on roof. If this is a pull out disconnect make sure it is installed the right side up. If no issues with high voltage you may have a blown fuse on the low voltage side. Turn power off at disconnect, open machine and look for a small,blade style, like one for a car, 5 amp fuse that may possibly be blown.
Jun 13, 2017 | Heating & Cooling
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Panasonic ac unit keeps coming up with a fault.... the error code is F90 air con is 5kw
dont no the code but if you call pana and tell them the code they should no what it is. not always usefull as they can give a general response but worth a try. then post the answer.
Jan 20, 2013 | Panasonic Heating & Cooling
LG B30AWY fault code ch 12. air con unit not working. any ideas???
thanks.
Feb 07, 2011 | LG Heating & Cooling
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
Remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Sep 19, 2009 | Heating & Cooling
F05 Fault code
this will be the motor brushes
Jul 07, 2009 | Bosch Axxis WFL 2060 Front Load Washer
KELVINATOR KSR20C
Aug 02, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
