How to clean Filter on indesit 1600 wie167 - Washing Machines
  • 135 Answers
SOURCE: Indesit WIE167 washing machine, displaying F03,
Error code f03 relates to the thermistor on the heating element.
This can be a faulty thermistor or bad contact between it and the control board.
Worst case scenario is a fault with the board which would mean a replacement.
Hope this helps & thanks for using Fixya
Posted on Dec 20, 2008
barkencoa
  • 3463 Answers
SOURCE: indesit WIE167
Hi, and welcome to Fixya.
F03 is indicating that the wash thermistor is open or short circuit.
The thermistor is part of the water heating circuit,so the only thing you can do is to test the heating element for continuity or an earth fault..If faulty, replace.
If it is o/k then you will have to call an engineer.
Plz rate my solution.
Thanks, And a merry xmas.
Posted on Dec 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Indesit WIE167 washing mashine
Remove the rear panel of the washer.
You will see the heater element at the rear of the drum,it has 2 wires going to it.
The thermistor as it is called is located at the end of the element,, unplug the connector on the thermistor. and pull the old one out, refit new thermistor, and connector.
Thanks.
Posted on Jan 06, 2009
  • 25 Answers
SOURCE: Indesit 1600 WIE167 washing machine
locate element and remove you should then be able to remove bra wire they normally get caught around element
Posted on Jul 16, 2009
  • 53 Answers
SOURCE: What does F-12 mean on the Indesit WIE167 washing
F12 - Communication error between main printed circuit boards. check connections.
Posted on Oct 29, 2009
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
The belt in my indesit WIE167 washing machine has come off and it is too tight for me to put back on, any suggestions.
You need to loosen the motor fitting or the pulley settings so that the belt can be place over the groove of the pullery and pushed forward so that it will fall into place.
If you use a small lever to wedge it will be easier to push it on to the pulley .
Place one end to the pulley and push forward.
Aug 20, 2011 | Indesit W 123 Front Load Washer
My indesit W1E167 1600 washing machine is flashing F-05, is there anyway I can unlock the door? It seems to go through the wash cycle but then perhaps gets stuck on the spin?
Error code F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, check for obstruction here and in the pump.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Select Brands Washing Machines
What does F-12 mean on the Indesit WIE167 washing machine? I have lost the manual.
Oct 29, 2009 | Washing Machines
Jul 01, 2009 | Washing Machines
Thanks.
Jan 06, 2009 | Indesit W 123 Front Load Washer
Indesit WIE167
Dec 20, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
