Question about Polaris Pool & Spa
Polaris conduit gets tangled and wont move - Polaris Pool & Spa
My backup valve on my polaris 380 is not shutting would this cause hose to tangle
no the swivels are stuck move them by hand till they loosen up or replace
Jun 09, 2014 | Polaris 380 In Ground Pool Cleaner
Motor runs fine bu sometimes wont move
It could be the belt is worn too thin and the clutch won't engage. Try a new belt and see if that solves the problem. Hope this helps.
Dec 31, 2013 | Polaris New Genuine Polaris Snowmobile...
My Hayward pool cleaner hose keeps getting tangled
check to see if swivels are free if not move them or replace also cold water will do it
Aug 24, 2013 | Polaris 3900 Sport Pool Cleaner ()
No My polaris hose keeps getting tangled up, how do I fix it.
Remeasure the pool cleaners hose to verify that it is adjusted to the proper length for the pool shape. With the Polaris operating, check that the swivels in the hose and the hose connections turn freely. Make sure feed hose is floating.With the Polaris turned off, spin each of the wheels. All wheels should turn together.
Nov 13, 2010 | Polaris 280 Black Max Pool Cleaner with...
My polaris keeps getting tangled up. How dod I fix this?
If the hose on these pool cleaners is becoming tangled, there are a couple things you will want to check. Remeasure the hose to verify that it is adjusted to the proper length for your pool shape. With the cleaner operating, check that the swivels in the hose and the hose connections turn freely. Make sure the feed hose if floating. Then, with the Polaris turned off, spin each of the wheels. Make sure they are all turning together and adjust if they are not.
Aug 11, 2010 | Polaris 280 Black Max Pool Cleaner with...
Pool & Spa Logo
20 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
