Question about Logitech Cordless USB Freedom 2.4GHz Wireless Joystick - 963283-0403
No light on the controller, either orange or green
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Have a rheem 90 plus gas furnace, the problem is that when you call for cooling the indoor blower does not come on. on the control board there are 2 green lights and one orange light. the top green ligt is...
Trunthe fan from the automatic position to the on position, if the blower does not come on then you
might have a relay problem. The relay is built into the
board, you may have to replace the board.
Jun 14, 2010 | Heating & Cooling
Forgot to color coade what goes where when taking out my stereo to put a new on in .. dont know which wire is for what
  1. LT Green - LR Speaker +
  2. Gray - RR Speaker +
  3. Red/Green - LCD Control (Light Dimmer Control)
  4. White/Black - Power
  5. Brown/Black - LF Speaker +
  6. Orange - RF Speaker +
  7. Green/Black - LR Speaker -
  8. Gray/Black - RR Speaker -
  9. Black - Ground
  10. Red/Yellow - LCD Input (Light Power Source)
  11. White - Memory Power Wire
  12. Brown/White - LF Speaker -
  13. Orange/Blue - RF Speaker -
Dec 07, 2009 | 1999 Chevrolet Tracker
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
Apr 21, 2009 | 1993 Ford Explorer Limited
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Canon i950 flashing orange green orange green
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Aug 22, 2008 | Canon i950 InkJet Photo Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Logitech Cordless USB Freedom 2.4GHz Wireless Joystick - 963283-0403 Logo
66 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
