Question about Seagate Computers & Internet
When i open up my computer there was an error popping up. csm error
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
BIOS / CSM problem
make sure the cmos battery is not dead.
Jul 05, 2016 | ASUS Computers & Internet
Asus p5g41t-m csm motherboard is having LAN problems
Go to Control Panel and Device Manager. Check Network Adapter for normal. If all appears normal go to Network and Sharing Center to setup a connection. If still unable to make a network connection then download the LAN driver for Windows 7 from ASUS at this link and install it.
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5G41T-M&os=&hashedid=FaRsjolgBLJKq49g Then reboot and try your connection again.
Dec 03, 2011 | ASUS P5G41T-M/CSM Motherboard
Need driver M2NBP-VM CSM for winwows 7
http://www.driversbay.com/drivers/bios-motherboards/asus/m2nbp-vm-csm/
Feb 06, 2011 | ASUS M2NBP-VM CSM Motherboard
A8N-VM CSM motherboard drivers for LAN where to get them?
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 31, 2011 | ASUS A8N-VM CSM (00610839133826)...
The doors lock automatically on my daughter's '99 Cougar. This has happened to me when I left the keys in the ignition and closed the driver's door. After AAA came and unlocked the doors, I removed the...
shorted wiring in doors or shorted door lock actuator in door. A grounding of a wire makes them lock normally. SO, any bare wire touching metal will ground it and lock the doors.
Principles of Operations
The Door Switch Lock Function When a door lock switch is moved into the lock position or a door lock cylinder is rotated to the lock position, the door lock switch grounds the lock circuit input to the central security module (CSM). The CSM then provides 12 volts to one side of the door lock actuators contained in the door latch unit and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors. The 12 volts that the CSM provides to the door lock actuators are provided to both door lock actuators from a single pin on the CSM electrical connector.
The Door Switch Unlock Function When a door lock switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the CSM. The CSM then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch unit and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which the unlocks the door(s). The 12 volts which the CSM provides to the door lock actuator(s) are provided to each door lock actuator from the individual pins on the CSM electrical connector.
CSM Self-Test The CSM has a self-test which can be entered into by using a diagnostic tool. This self-test will monitor the following CSM door lock inputs:
  • Unlock switch (DTC B1311)
  • Lock switch (DTC B1300)
  • Exterior lock switch (DTC B1309)
  • Exterior unlock switch (DTC B1341)
Before running the self-test, the following conditions must be met:
  • The ignition switch must be in position II
  • The driver and passenger doors must be unlocked
  • The driver and passenger doors must be opened
  • The hood and liftgate must be closed
  • The set/reset switch, and liftgate release switch are not actuated
It is important to note that all of the diagnostic trouble codes (DTCs), with the exception of B1551 and B1553 can be retrieved with the self-test. DTCs B1551, and B1553 are continuous and will only be retrieved if the liftgate release is operated prior to retrieving the continuous DTCs.
Inspection and Verification
  1. NOTE: Make sure that the battery is fully charged before starting electrical diagnosis.
    NOTE: Prior to carrying out the CSM Self-Test, make sure that both the driver and passenger doors are open.
    Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Binding latch mechanisms
  • Binding linkage
  • Misaligned door
  • Central junction box (CJB) fuse(s)
  • Wiring harness
  • Electrical connector(s)
  • Door lock switch(es)
  • Door lock actuator(s)
Module Controlled Functions
The central security module (CSM) covers the following functions:
  • Central door locking
  • Double door locking
  • Anti - theft alarm incorporating
    • forced entry
    • radio theft
  • Radio frequency remote control of
    • central door locking
    • panic alarm
    • driver door unlock
    • liftgate unlock
For additional information, refer to Section 419-01A Anti - Theft - Active, Section 501-14A Handles, Locks, Latches and Mechanisms, and Section 501-14B Keyless Entry/Computer Operated Locks.
The CSM is in the passenger side kick panel I think.
Good luck
Jan 25, 2011 | 1999 Mercury Cougar
How to change the lock code on the door
The owners manual has directions on changing or adding a personal code.
If you are talking about the factory code, the only way to do this, is to replace the CSM ( Central Security Module, mid 2000 MY and older it was called a RAP - Remote Antitheft Personality )
A RAP and CSM are not 1 for 1 pin compatible, so if you go to a junk yard for a new CSM, make sure the build date on the truck is 2-OCT-2000 or newer ( up to a 2004 Heritage or Lightning, not the new body style 2004 ).
The CSM is up behind the dash on the driver's side.
The CSM is the white color box center of this picture, that is the parking brake on the left side of the picture.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
The setting a Personal Code for the door keypad starts on page 111 in the 2002 owners manual.
Oct 25, 2010 | 2002 Ford F150 Regular Cab
USB Device not Recognized
right click my computer then click properties - hardware- device manager.  Scroll down and you should see some errors.  click on them and update drivers
Jan 30, 2009 | ASUS M2NBP-VM CSM Motherboard
Nikon D70 The flash won't pop up and a clicking sound when I push the shutter. Also get r03 error. Jenean Stone
HI,
Remove lense, replace
Remove battery, replace
Change shooting mode - try full auto, jpeg not raw
Reset camera to factory defaults
Replace/format CF card
Nov 01, 2008 | Cameras
Nikon d100 error code r03
If you have a "r03" display, then you need to go into your CSM Menu, and scroll down to CSM #4, and turn LONG EXP. NR to "OFF". When you are in Noise Reduction Mode, your D100 buffer is literally cut in half.
Jan 01, 2008 | Nikon D100 Digital Camera
Computers & Internet Logo
14 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
