Question about Olympus FE-190 Digital Camera
Spare ecp for bosch 36v li battery - Olympus FE-190 Digital Camera
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
My Bosch chainsaw is very temperamental. It try's to start but usually won't kick in until I have given it a few thus. Even then every time I stop the saw it will not start again. The battery is full...
My brother used to sell chainsaws to fire departments.His rule was always do two things first: 1) Get new gas -- it doesn't matter how old you think your gas is. 2) Replace the spark plug -- again, it doesn't matter how new you think it is. He says that this solves 90% of all starting problems.
Jan 12, 2014 | Bosch AKE 30 LI Cordless 36V Chainsaw with...
Replacing brushes Bosch impact driver
If it has the replaceable brushes it should be no problem, just unscrew and replace. Try oasistools.co.uk
Dec 28, 2012 | Bosch Gdr18v-Li 18V 2-Speed Multi-Function...
Hi I've got a bosch 36 vf li and I'm struggling to open it up to change brushes. I've undone all visible screws but still struggling with top part of unit.
Have you removed the 4 gearbox screws? the cover should lift off. sometimes if a brush holder has over heated then the two halves get stuck together in places.
Dec 04, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
I have a Bosch 36v LI cordless drill the batteries are fully charged. However, when I pull the trigger, it starts briefly and then shuts down almost acting as though It's batteries are dead. I have...
One possibility is that the trigger on your drill has a short in it. When you replaced the brushes did you clean off your commutator? I am assuming that you did. You only need to clean the brush dust off of it and ensure the copper contacts are clean. Your issue is definitely with your drill. I am not sure about Bosch but with some drills you can take apart the trigger and check for contamination. Hope this helps.
Oct 23, 2017 | Bosch Drills
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Olympus FE-190 Digital Camera Logo
16 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
