Question about Cisco NSS 324 Smart Storage Network Storage Server NSS 324
How to replace battery of cisco 7603-s on mother board
Authorization code for seriel number 1045-1756-2071-0999-3438-3575
1326-1420-8946-6213-0575-4758
Jack
flying200809@gmail.com
any friends who were looking for below products, welecome you to contact me,
Professiona wholesaler and retailer: for below products
1) projecot sapre parts, such as color wheel, lamp, mother board,DMD. lens, etc.
2) computer mother board,
3) HP server, switch, router. Cisco router. switch etc.
4) server or router memory
5) GBIC OR SFP
Nov 30, 2011 | Adobe Computers & Internet
Light outside screen
hi sir
try to recheck your machine data, rely on those instruction, adjust the distance between projector and screen.
Jack
5) GBIC OR SFP
Nov 28, 2011 | Optoma DX602 DLP Projector
I want to replace the CMOS Battery in IBM 29R9284 mother board. But I am not able to locate the CMOS Battery in the mother board. Can someone guide me on this to know whether any CMOS Battery is installed...
Hi, here you can download drivers and a manual:
http://support.lenovo.com/en_US/?sitestyle=lenovo&lndocid=MIGR-56602
You can use the autodetect function in seach for your model.
IBM has changed name to lenovo.
The cmos battery look like this:
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=r4fDSQap2Qo&playnext=1&list=PLD78BD157A0D15923
Hope this will help you.
Aug 21, 2011 | IBM 29R9284 Motherboard
How to unlock bios of toshiba portege m500
two options
1. look on the mother board for a small round battery about the size of a nickle, remove it, start pc, after start up shut down, replace battery, start up again... or remove battery, let sit for about 30min, replace battery start pc.
2. look for a small red or yellow toggle switch or button on the mother board, (should say "reset bios") push button, restart pc.
i assume this is a lap top so there will be some disassembly of the unit, not to extreme though, usualy the battery and the switch/button are next to one another and located toward the front of the mother board, and if in lap tops the battery or batteries are in a plastic covering wired to the mother board with a small connector, just unplug connector if you cant find the reset button.
hope that helps
Mar 23, 2011 | Toshiba Computers & Internet
Please i have an acer laptop 8920g with a burnt chip Q507. please i need the serial no of this chip so as to get an exact replacement.
tried this on a cisco router they change chips faster than making new laptops, in all honesty it would be easier to buy a new mother board.
Feb 03, 2011 | Computers & Internet
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
My Laptop DV6000EU in Aug 2007. Warrenty on Mother board
it should be under waranty seeing that the motherboard is malfunctioning again. normally the hardware will go out before the motherboard and seeing that its the same problem again mark the motherboard in a nice little place with a marker to insure they are not doing a repair and giving you back the same faulty board.
Nov 12, 2009 | HP Pavilion dv6000z Notebook
Pc starting problem
There is a battery on you motherboard and it needs to be replaced. Usually it's a large round lithium battery. If you replace that it should go to default.
Mar 10, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mother board post
Yes, if replacing the cmos battery does not solve it, then maybe the power supply also is faulty.
Thanks,
Lolita
Apr 30, 2008 | Matsonic MS8137C Motherboard
Computer won't acknowledge power souce - shuts down
Try taking the battery completely out and see if it works then.
Mar 26, 2008 | HP Compaq nc6320 Notebook
Cisco NSS 324 Smart Storage Network Storage Server NSS 324 Logo
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
