Question about Health & Beauty
What is normal plus rate? - Health & Beauty
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
What is an approximate cost to replace front seal and housing seal on a 1997 Mercedes C230?
Depending on labor rates about 6 hours plus parts seal bushing and fluids
Dec 12, 2014 | 1997 Mercedes-Benz C
What is the correct pulse rate for a 57 year old male
Vital signs are specific to every person but as a general rule,
Typically a normal resting pulse rate is anywhere between 60 and 100 beats per minute. Middle age good physical condition 80 beats per minute plus or minus 10 beats per minute is about right. If you're out of shape closer to 100 per minute very athletic closer to 60. A bigger concern is blood pressure as this will also influence pulse rate. There are too many factors to consider to simply post online. Such as overall health, cardiac function, as well as medications and life style. For example, caffeine and stress will increase your rate.
hope this helps.
Mar 03, 2014 | Measuring Tools & Sensors
Whirpool gold washing machine(top load).Seeing alot of water,so i took the rinse/drain hose off the back to make sure it wasnt cloged.I then kept it of but started a normal wash and as soon as the water...
Sorry to read about your problem, I hope this helps you out.
no it is not normal, i suggest you contact a service company. A repair will cost alot less than a new washer...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Where do I type in the ip address to get to the configuration for my dlink air plus extreme router after I connect the computer to the router and resest the router by hold it in for 10 seconds?
hi, start your internet as you would be trying to connect, in the top search bar type as follows
http://192.682.1.1 or 192.168.0.1 normally the user name will be : admin and normally the password would be : password you may have a different ip address than the 2 i have given as an example, it normally says on the label under the router itself what this will be r with the cd that came with it...hope this helps please vote and rate thanks
Sep 03, 2010 | D-Link Computers & Internet
How to use camera. I suddenly have my photo's in black & white plus getting a blurr. Want to be able to work the camera a lot better, than I am
go to camera then options and then effects select normal there. your prob will be solved if not let me know
thankyou for using fixya free solutions - kindly rate my solution.
Jun 22, 2009 | Samsung SGH-G800 Cellular Phone
Front loader will only wash on normal cycle
The ECU is likely bad. Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore HE2 Plus Front Load Washer
Griding sound in Ice Magic Plus box in freezer compartment.
Hello garydeanr,
Welcome to fixya.
You said,, There is a constant grinding sound in the Ice Magic Plus compartment in the freezer compartment. The ice maker is making ice.
What is your exact model number and How Old is your fridge?
I'll be able to run it through the repair system and check for you!
Waiting your response!
I believe that,
From here this sounds like one of many normal sounds. is a normal sound.
You can go to this site and scroll to page 9 where it will tell you all the normal sounds your fridge can make.
I tried to cut and past it here for you, but it is not copyable from the site!
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202220699.pdf
I think you can rest assure that it's okay.
Huuum ,
Please remember to leave a rating!
Oct 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
