Question about Cooktops
I have a panasonic th-l22x20h Id tv. how to view images and music at the same time.
Model # RY 160LXTS sometime the broil come on by it self, causing the smoke alarm to goes off, what can I do to fix this problem, the range is 2 1/2 years old
if this is the model with the touch control buttons on front , ive seen a stove top spill that got down inside there cause some missoperation ,id start to look there for a reason , then id move on to replacing the control panel and last the logic board (its on back of front panel ) but I will say id unplug it till I resolved this problem if it turns itself on and your not home ,what could happen !!!!
Apr 09, 2016 | Whirlpool 4.5 cu. ft. Electric SlideIn...
60inch lg faltscreen that after 13 months decided to act up. The entire screen goes blank but the sound is still working.
Power inverter board issue, capacitors might need to be replaced. When the TV is on hold a bright flashlight really close to screen if you can see a faint image that is your problem.
Nov 16, 2013 | Cooktops
The number stickers for controlling the temperature of my cooktop have worn off
get a permant marker and if you can remember were the nomber 1, 2, 3. are then you can rewright them back on or you can go th a service place for wite goods and proberley by a new one
Dec 31, 2011 | Cooktops
How to clean the cooktop fan
as always turn off the power , I have tryed several types of cleaners over the years but fantastic works th best
Dec 04, 2011 | Jenn-Air Cooktops
When using a burner and turning a knob the cooktop tripped a circuit breaker, how do I check what happened?
is this a common occurance or a one time thing? if it's common the cooktop might not be wired to the supply correctly causing th phases to be unbalanced drawing too much current from one phase instead of both evenly ish. you'd have to meter it out to see but if you aren't knowledgable with electrical stuff get an electrician to check it if it only happened the one time and isn't anymore probably don't need to worry about it
May 07, 2011 | Maytag 30" Built-In Electric Cooktop -...
Whirlpool Gold ceramic cooktop removal.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Dec 14, 2008 | Cooktops
I need to remove my Whirlpool Gold ceramic cooktop.
Dec 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
Burner clicks a long time before igniting you can smell the gas
Not sure about what part 1 is about. #2 indicates a failing ignitor gap or a bad gas mix. Get professional assistance.
Jun 13, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cooktops Logo
75 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
