Question about Vizio Televison & Video
Can't change from HDMI2 back to HDMI1
I wanted to watch a Blue Ray movie on my player which is connected to HDMI2. I had to update my disc player using my USB and I did, we watched our movie but now I am unable to switch back to HDMI1. Unable to switch to any HDMI source. I changed the batteries, and all other functions work fine (on TV remote, DVD remote, and DIRECTV remote). I have used this function at least 4 other times without any problems, but now it is like "locked" onto HDMI2. I have turned the power off to all devices without results, hoping to reset to default. Any suggestions?
    Master:
  • 595 Answers
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Posted on Apr 29, 2017
tvtek
  • 1284 Answers
SOURCE: no picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
  • 3 Answers
SOURCE: Unable to control audio after playing a DVD using HDMI
you may have a damaged remote circit or reciver on the dvd player or tv, look for a phone number on the instructions book to call and see if you can send it in to have it checked out
Posted on Jun 02, 2009
SOURCE: no picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Posted on Jan 07, 2010
  • 73 Answers
SOURCE: Shortly after the cable receiver and plasma TV
i think logitek is complicating home entertainment with the notion of simplifying the quantity of remotes/devices people have. use the remotes that came with the device. its a lot of cash for a remote that causes so much frustration and complications. so we feel it is necessary to pursue the idea of One Holy Remote. Save yourself the headache, get rid of that nightmare and use the two or three remotes that came with your stuff. everytime i see one of those remotes in my customers hands, i think oh god not another one.
Posted on Jan 21, 2010
budmrtn
  • 11361 Answers
SOURCE: Hooked up to a Directv
No pictures on ALL mode? DVD, DIRECT TV, etc? How about using the component video output or composite video out put of the Direct TV?
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/
If it is TV problem, then please try this:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 10, 2011
Can't keep the HDMI2 setting for watching streaming channels - TV automatically reverts to HDMI1
That's because you have connected another device in HDMI1, the TV detects it as power on, and then change HDMI2 to HDMI1.
Try to power off the device in hdmi1, or you can even try to change HDMI2 to HDMI1 port ;)
Jan 15, 2018 | Televison & Video
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Aug 16, 2016 | Televison & Video
Switching HDMI inputs
Plug all cables in the ports in the back of your television, the use the remote of the television select Source scroll up or down for required hdmi channel select buy stopping it on the channel then press ok
Jan 08, 2014 | Televison & Video
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
Nov 29, 2013 | Proscan Televison & Video
I'm trying to watch a 3d movie in my blue ray 3d
First off is your TV a 3D TV. If it is you should be able to go into the menu setting (or on the remote) and change the display from regular TV to 3D. Then your 3D blu-ray player should recognize it.
Jul 15, 2017 | Televison & Video
My rca blueray dvd player will only play dvd not blue ray
What model player do you have? What movies are you trying to watch?
Check if there is a firmware update for your player. If your player is older and your movie is a recent release, you may not be able to watch it unless there is a firmware update. (If no updates are available, the manufacturer wants you to replace the unit.) Due to changes in copy protection and codecs, new movies can't be interpreted on an older player.
I hope this helps. Please add a comment with the model number of your blue-ray player for more support.
Mar 08, 2013 | Televison & Video
Do I connect my DVD player to my freeview box or direct to the tv
I would connect to your tv because you should be able to select what input you want to use from there. I.E. HDMI1, HDMI2, Video1, Video2, etc etc
Apr 09, 2012 | Sony Televison & Video
Won't play new blue ray disk
Will your machine play standard movie DVD discs? if it does then the laser pickup assembly is the problem. The blue ray discs require a higher precision tracking to offer better resolution.
Dec 23, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Hdmi connection blueray to sony tv bravia.sony bd. pluged to hdmi2 unable to get picture. hdmi1 being utilize by cablebox. should i change hdmi setting on tv, how is that done.
there should be a imput button on original remote. just push it then scroll to hdmi2, then enter should give you picture if not they will be an imput option under your menu options
Feb 09, 2010 | Sony Blu-ray/dvd player BDP-S1
Televison & Video Logo
308 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
