Question about Samsung Lands Phones
Find earlier in coming calls - Samsung Lands Phones
I'm trying to install this thermostat but the old thermostat has three black and three white wires. I installed one early and had no problems with it. Any help would be greatly appreciated?
You will have to find the black and white set that come from electric panel and you can use a meter to find that out. After you find which set it is then you can put those wires on the LINE side of the thermostat and the rest of the wires the 2 blacks and 2 whites will get connected to the load side. I would recommend turning the power off when you are connecting the wires and I also recommend calling a electrician so you don't get hurt or killed. Even if it costs you a few hundred dollars it's better than costing you your life.
Good luck and just call somebody that's licensed to do this kind of work and let them do it right and not burn your house down
Mar 25, 2016 | Heating & Cooling
I have a weathermaker sxc 060- gg. Last year the heat would come on but not get that hot, this year the heat won't come on @ all, just blows cold air. I can smell a faint gas smell when I take off the...
The gas line has air in it, Turn the unit off, at breaker or unplug it. Bleed the air out of the gas line, It should take about 5 seconds to bleed. Tighten gas line, Plug or reset breaker and unit should fire.
Nov 22, 2013 | Heating & Cooling
Best way to replace stock hoses on the back side of the oil bag on a 2003 heritage softail ,remove fender ,seat battery???
I think the lower part of the rear fender will come off. On the earlier models it would. It's called a "mud guard" or "splash guard". Of course, you'll have to remove the rear wheel to get to the screws.
Good Luck
Steve
Aug 25, 2011 | 2000 Harley Davidson FLSTC Heritage...
Furnace not lighting light blinks once at first.now no blink.just stays on comes on and does not light.hear clicking noise no light.blower does not come on.was workin fine earlier
call a service technician
Without knowing exactly what you're looking at, you can seriously damage your furnace, or even start a fire.
Good Luck!
Feb 12, 2010 | Heating & Cooling
Lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Oct 20, 2007 | Nokia 1100
Caller-id quit working
I have the same problem with my unit. Emerson customer service made some suggestions, including pulling the 9V battery, disconnecting the phone from phone and power for 3 hours, etc. Their first suggestion (earlier this morning) was to Push "Up" button and hold for 4 seconds, then pressing the "delete" button three times and re-pressing the "Up" button for 6 seconds. That procedure failed. I'm in the midst of the 3 hour wait after full disconnect of phone line and 120V plug. I don't think my phone will come back. I'll be happy if it does. Good luck with yours...Richard
Jan 12, 2007 | Emerson EM-CKT9087 Corded Phone
Lands Phones Logo
10 people viewed this question
Top Samsung Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
imfedup19
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
