Question about Philips Televison & Video
Diagram 21pt2252 68r
Vertical line problam
2 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: white vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Posted on Aug 30, 2009
What is Horizontal scan output fault? is HOT is faulty or other problem?
Horizontal scan is the scanning left to right on the screen to make up the width of the picture. The height of the picture works the same. This is not an easy thing to repair. You will have to find someone wit the experience to troubleshoot it.
sorry but hope this explains a little.
Jan 28, 2015 | Televison & Video
Vertical lines screen
LCD cable is loose inside PC, need to be opened up and reseated or replaced, if under warranty call DELL support to request onsite tech to repair.
Oct 18, 2017 | Dell XPS M1330 Notebook
LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
No vertical deflection, just a line in the center. I don´t have the diagram. Tanks
Look up for faulty Elkos in the vertical Stage near the powersuply abd then find the Vertical IC with are fit near by the highvoltagetransitor
Sep 05, 2009 | Daewoo DTQ-13P2FC 13" TV
White vertical line on monitor screen
Aug 30, 2009 | HP Pavilion zd8000 Notebook
My ctv vartical hight problam
vertical circuit not working
Jan 22, 2009 | Televison & Video
Mitsubishi cs27403c tv problem
kindly...see first the flyback and adjust the screen if the horizontal line still there adjust the fucos....
Jan 08, 2008 | Mitsubishi CS-27405 TV
Resistor R410, in schematic diagram FILE NAME: power, for TV Samsung CK-5339ZB was burn, I replace with new one, but it burn again. What can be reason for this
if you are talking about vertical section 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. hope this will help. as per schematic diagram go to www.serviceinfo.com good luck
Oct 04, 2007 | Samsung TXN3271HF 32" TV
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Televison & Video Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
