Question about Roland Boss DB60 Dr Beat Metronome
Dr660 won't turn on
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
Why won't my vestax vmc 002 turn on
Try replacing the fuse by one with same voltage and rating. Usually if you take a look at paperwork that came with the mixer it will show you which fuse you should use.
Jan 05, 2013 | Vestax Vmc - 002 Xl
Alesis Multimix8 started smoking and now won't turn on. If it is a fuse or something how do i replace it?
A blown fuse will not produce smoke. A component failed and probably fried a resistor, which would smoke. That in turn would blow the fuse.Just replacing the fuse will not cure the problem. Your unit needs repair.
Dec 27, 2012 | Alesis Multimix 8 USB 2.0 - 8 Channel...
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
Wont turn on. even with new battery
Presence of the inout guitar cable enables the unit to turn on. If the cable is present, and it won't turn on, the problem is likely internal. Cracked circuit boards and broken solder joints, especially at connectors are common.
Aug 27, 2011 | ProCo Rat2 Rat Distortion Pedal
My P85 simply won't turn on. I have tried two different adaptors. Neither work yet they are functioning with other keys. Please help. I have a gig on Sunday
What adapters have you tried? The P85 REQUIRES a 12 VAC adapter, NOT the common DC type and it needs a 1.5 amp (1500 ma) type adapter. If you connected a DC adapter it will NOT do damage, the unit just won't work. You can find adpaters on Ebay or Google search.
Aug 26, 2011 | Yamaha P85 88Key Portable Digital Piano
My amps won't turn on. There are 8 amps plugged into individual boxes but they are controlled by one switch on the sacr
Not uncommon for a switch to fail... especially the weak types they use on these strips. The inrush current when turning on the amps makes quick work of these switches. Replace the switch and get spares for the next time it fails.
Jul 08, 2011 | Atlas Translator Atlas SACR191 6Channel...
Yamaha psr230 keyboard wont turn on
I was bird so I got on my yamaha won"t I c it and it don"t turn on
Oct 19, 2008 | Yamaha Full-Size Keyboard
Roland Boss DB60 Dr Beat Metronome Logo
23 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
