Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
check carriage home postion sensor(often in your left hand near left end of the machine-check for a broken connector and reconnect it-check for droped object or dirty in the sensor.
