Question about Sewing Machines
Adjusting bobbin tension homedream design line fy812
2 Suggested Answers
SOURCE: Loading the bobbin and adjusting the tension.
Loading the bobbin for this maching is fairly simple. First thread the machine. Then after placing the bobbin in the machine pull the thread out through the first notch and back through the second. (The end of the thread should be going in the direction of the little channel on the left side of the bobbin area.) Now what I did was make a loop with the end of the thread and pushed it under the casing below the needle. Then if your machine is threaded correctly you should be able to turn the knob on the right side of the machine so the needle goes down and comes back up once. If you've done it right the bobbin thread should come up in the correct spot.
Posted on Mar 15, 2009
Tip
Always Check The Manual Before Opening up Your Machine To Solve Problems
The Yamata sewing machines also go under about 6 other names
AEG
YAMATA
HOMEDREAM
FEIYUE
PRIMERA
VICTORIA .
There is a PDF Download of a Universal Manual for these models
It is for many models from a FY700 up to FY812 and more.
The PDF is in English & Chinese and can be downloaded FREE from here
http://www.hennyreimerink.nl/MANUALS/FY700-English_Chinese.PDF
on May 14, 2014 | Yamata FY811 Mechanical Sewing Machine
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
Yamata fy811 sewing machine
AEG
YAMATA
HOMEDREAM
FEIYUE
PRIMERA
VICTORIA .
Feb 08, 2013 | Yamata FY811 Mechanical Sewing Machine
Feiyue
AEG
YAMATA
HOMEDREAM
FEIYUE
PRIMERA
VICTORIA .
It is for many models from a FY700 up to NM900.
Sep 14, 2012 | Yamata FY812 Mechanical Sewing Machine
My daughter bought a homedream design line FY812 sewing machine in 2005, unfortunately, she cannot find the foot pedal control attachment and so I wonder if you can let me know where we can order the part...
here are some site to try, I suggest to call them or email & ask them about the foot pedal
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingsupplywarehouse.com
sewforless.com
Sep 19, 2011 | Yamata FY812 Mechanical Sewing Machine
Marie Osmond emotions embroidery machine...how do i delete saved?
Check the tension. Bobbin tension. You need to use only Isacord thread. The cheap stuff will get caught and break the needle everytime.
YES you can delete designs. When the screen is up that is showing you what it is stitching. Click on grey box that pulls up everything you have ever stitched and click on one and then select delete.
Jun 17, 2009 | Yamata FY812 Mechanical Sewing Machine
Tension not correct
Just set the tension on the bobbin casing but very little at a time, to much and you will never get it wright again. Then also try the tension at the top after adjusting the bobbin casings tension.
Mar 01, 2009 | Singer CE-200 Quantum Futura Computerized...
Yamta fy812
Am looking for the manual for the Yamata FY812 sewing machine. Anyone have one or know where I can find one?
Thank you..
Aug 25, 2008 | Yamata FY812 Mechanical Sewing Machine
Breaking thread
Try adjusting the tension in the "Set" menu. "Tweaking" anything else may end up costing money.
First, make sure the hook area under the bobbin case is free of debris. Try a new bobbin and a new spool of thread with a new needle, full inserted. If the needle threader isn't lining up, the needle may not be in right.
Jul 12, 2008 | Husqvarna Designer I
Sewing Machines Logo
16 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
