I have a E150 ford econoline that the AC is not putting out cold air, just cool. It also sounds like the AC is cycling on and off. It may need a recharge. Which Freon Gas does this year use, R-12 or the newer R134?
  • 11,896 Answers
If it is 95 and older it is R-12. If newer it is R134. You can buy kits with freon and guages for around $40
Posted on Jun 18, 2009
94 ford econoline f150 is blowing cool air not cold, can you help in tell me what can be the problem
have you checked the systems pressures? if it is cool but not cold then you may need to add some freon to the system.
Jul 27, 2011 | 1994 Ford Econoline
My b/f's 2000 ford econoline e150 is having
Have you checked the transmission fluid? just make sure that when you check it, the engine is running
Jun 25, 2011 | 2003 Ford E150
I was needing a fuse wiring diagram for a 75 ford econoline ambulace van
a haynes manual will have a rough version of the factory wiring diagram, the factory fuse box is marked. the aftermarket parts of the ambulance will have to be traced out.
Sep 04, 2010 | Oil Filter Ford E150 Econoline Club Wagon...
No hot or cold air coming from dashboard vents on a Ford 1993 e150
1993 ford e 150 horn or cruise control do not work
Aug 31, 2010 | 1993 Ford Econoline
Once started, the engine stalls on my 99 Ford E150 Econoline V8. If I hold down the accelerator, the engine runs fine. By the way, it is cold outside too.
check the air bypass valve on the throttlebody at the air inlet try tapping on it and see if it will idle ok
Dec 07, 2009 | 1999 Ford Econoline
I cant find the radiator cap on my ford econoline
econolines donot have caps follow the top hose and it will lead to a clear or white bucket and that is where you put fluid in
Jul 14, 2009 | 2001 Ford Econoline
97 Ford Econoline air conditioning and vent settings blowing hot
I know from experience that if the coolant is to low ( not just the freon levels in the compresor but the antifreeze/coolant level as well) the AC system will not cool and will blow hot. Check the coolant Antifreeze and freon levels, even with the Coolant being a little low my 1998 Ford E150 Van will blow hot. After you have ruled out of these possibilities and the chance it is the thermostat most likely the problem is what Ford calls the "Flap" it controls the air flow through the vent system when you switch from Heat to AC. When the Flap is working it closes off one systems air flow so as to not interfere with the current climate selection.
Feb 21, 2009 | 1997 Ford Econoline
I need to reconnect my alternator.
I went to the auto parts store where I bought the alternator.They had a tech their that knew alot about
fords and she help me resolve my delema.
Thank You ERC40
Nov 15, 2008 | 2003 Ford E150
Heating & Cooling Logo
315 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
