Question about Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine
Husqvarna mows for 5 minutes and then engine stalls
Old gas drained. New fuel filter installed. Battery charged.
5 Suggested Answers
  • 218 Answers
SOURCE: Engine stalls after 45 minutes?
Hi..my name is Keith...i would suspect either the fuel cap isnt venting..or if you have a fuel pump..that it is bad..i hope this will help..if not please write back
Posted on Jul 09, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
SOURCE: Husqvarna YTH2348 engine stall issue
Mine was doing the same thing. Just loosen the gas cap. If its on too tight the engine will stall because the air cant get into the fuel cell to replace the abscent fuel.
Posted on Sep 30, 2011
yakuzza2
  • 68 Answers
SOURCE: Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Posted on Jun 07, 2012
Engine was running OK when it started to slow down and finally stopped after about 1 minute. Wouldn't start again.
did you set up the engine or does it turn freely?
clean out fuel system drain gas and clean carb
Sep 27, 2015 | Garden
Truck will start but engine dies and service engine soon light comes on/truck was idleing fine for 10 minutes then began to hesitate then shut off when first happened
When the engine dies the Check eng light is supposed to come on. You need to do a fault code test on the OBD2 engine control module.
Jul 07, 2017 | Cars & Trucks
Husqvarna lgt24k54 keeps turning off
Interesting! Try seeing if it will run without the fuel tank cap on. There is normally a small hole to let air in as fuel is used, if this gets blocked the fuel will stop running from the tank. You probably won't be able to clean it well enough so a replacement cap shouldn't be too expensive.
Jul 17, 2013 | Husqvarna LGT24K54 54" 24HP Kawasaki Lawn...
Hard to start husqvarna yth2348-28957
try fresh gas gas is only good for 30days in small engines if the fuel is new then the carb might need a good cleaning
Aug 04, 2012 | Garden
Some water got into my gas can and I put the gas in the mow unaware of it. I mowed for about 30 to 45 minutes when the mow's engine begin to make a popping sound. IWhile draining the gas tank and...
If there is gas in the oil you drained from crankcase the carb is really dumping fuel(did you see black smoke?) If your carb has a drain plug drain it. If not you will have to take off the carb bowl and clean it. Check float operation, turn on fuel work float by hand to make sure gas shuts off when float rises to level position. If not may need needle and seat kit. Or adjust float.
Sep 28, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 engine stall issue 23hp B&S. Full charge on the battery 12.7vdc. New fuel filter. 13.5 - 14vdc at full throttle. Cranked right up cut grass 20 minutes +/- begins to sputter as if...
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Jul 08, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Jun 09, 2009 | Garden
1999 mazda miata that would start
Drained the old gas from the gas tank and refilled it with new, also replaced the gas filter and charged up the battery.
Apr 17, 2009 | 1999 Mazda MX-5 Miata
Husqvarna Rz5424 Zero Turn Lawn Mower Kohler Courage Engine Logo
83 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
