Xerox 4150 power supply fan locked - Office Equipment & Supplies
2 Suggested Answers
  • 24 Answers
SOURCE: Xerox 4150 not scanning to network
I need more information, like is it scanning using the SMB protocol or FTP. Are you using active directory, etc. Usually, when they just quit, it is due to a Microsoft security patch, or a software firewall having been enabled. If you're sure that it is neither of the above, try browsing to the Xerox via the IP address, go to the properties tab, services, network scanning, file repository set-up, and see if the login name used for network scanning is qualified: (i.e. - domain\username) Often, in a business environment, that will help.
Posted on May 26, 2009
Xerox Fuser will not warm up? Any idea why?
The fuser is nothing more than a heater element. One fuser is broken and the other isn't. You need a new one.
Or did you mean the broken one works in the other machine? In which case the power to it is disconnected somewhere.
Dec 27, 2015 | Xerox WorkCentre 4150 Black and White...
Xerox 4150 hard disk problem
First off you can only use a hard drive intended for the copier. Also when you put in the new one you will need the firmware fro the copier. THis has to come from Xerox. If you ordered the HHD from them it may already have it on them.
Nov 05, 2012 | Xerox 4150/XF WorkCentre Multifunction,...
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
I need to know what the part number is for the maintenance kit for work centre 4150
Here is a link to all the available parts and supplies for the Xerox 4150. This includes part number, yields and even pictures.
http://www.precisionroller.com/search.php?q=xerox+4150
Good Luck and Thank You for using Fixya.
Oct 12, 2010 | Xerox WorkCentre 4150 Black and White...
Xerox workcentre 4150 it say: System unavable do not power down until power down message comes up. Then when they power down and turns back on it comes up with same message. Can you tell me what to do....
This one probably relates to a failing CMOS battery 105N02093. First, though, you can unplug this battery for 30 seconds and try again. This is an inexpensive part, so start with the battery.
It could also be a defective hard drive 005N01086 or Main board 140N63141.
Whit
Item, Inc
Sep 01, 2010 | Xerox WorkCentre 4150 Black and White...
Xerox WorkCentre 4150 Error code: 20-800/The machine cannot save the fax settings to memory. Xerox service is required to inspect the backup battery. Faxing is disabled, printing and all other machines...
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Dec 17, 2009 | Xerox WorkCentre 4150 Black and White...
How do I open up the scanner glass to clean the scanner on Xerox 4150?
please do not do this if you are not xerox trained. you could use a damp cloth to wipe the entire glass
Nov 13, 2009 | Xerox WorkCentre 4150/C All-In-One Laser...
Black & White Setting
No, I have resolved the issue with Xerox tech support. FYI, in case anyone runs in to the same issue as I had. I updated the firmware image and the setting can be set or modified via the web console under Email settings.
Peter
Mar 18, 2009 | Xerox WorkCentre 4150p - Multifunction -...
15 people viewed this question
jasbo
jasbo
