Question about Refrigerators
Door water dispencer stopped working
Kenmore model 106.742.094.00
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Either the switch sensor has failed or you have calcium in your water ,with calcium buildup youll want to usually buy a new unit or flush the one you have with CLR
Posted on Jun 18, 2009
Check all circuts nothing is on (model #795.7834), does this refrig do a auto defrost and so do everything stop working even the water dispencer
is the light on on the inside of the machine if not then your machine is not getting power all fridges and freezers have an auto defrost cycle whether they be mechanicaly like the older ones or electronic like todays models defrost has nothing to do with you getting water to your door i dont actually think the power going to the unit is on if it is plz repost or send me a reply
thanks
Jul 13, 2010 | Kenmore Refrigerators
I have a kenmore side by side refigator and with built in ice and water in front door. The water does not fill ice maker or dispence out the door. The water stoped first at door then about one year later...
you might need to open the water pip and clean the volve on the bottom of your fridg. its get clug some time but if its not working then your valve need to be replace..get me your model # i get you the part#...
911servicetoday . com
Jan 01, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
Water dispencer and ice dispencer stopped working
Make sure the water supply line is turned on (the valve probably is behind the fridge or under the sink ) also check if is kinked or damaged.
Aug 25, 2009 | Kenmore Freezers
Icemaker is not working, but water dispencer is OK Model Kenmore Elite 106.45422800
Hi...
Try to check this
Good luck !!
Regards
PCmania
Jul 08, 2009 | Kenmore Refrigerators
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
I have a Kenmore model 106 9555710 SxS - no wate through door
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
Jun 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker
I have kenmore two door fridge. My icemaker is not working but the water dispenser is. Model#DU800DWGQ1 Serial#FJ1814737
May 14, 2008 | Refrigerators
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
