Question about Kitchen Appliances - Others
Menvier ts700 i cannot reset the enginers code, how do i unlock
Tip
How to enter Factory settings on GNR TS700 (Black/Silver) 17" LCD monitor
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
on Dec 31, 2009 | Computers & Internet
Stihl carb diagram
Here is the two types of carb fitted to the TS700/TS800
May 17, 2013 | Stihl 43991 - TS700 & TS800 Cut-off saw...
I have the LG Vu CU920 (White) and it has a security code right when i turn on the phone and my friend doesnt remember the code so how do i reset or unlock it? is there any buttons i can hold down to reset...
Try following this step :
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
If that way not worked you need to asking LG Vu CU920 unlock code from your network provider, They will give you the code within 2 week maybe more and takes some charge or you can buy LG unlock code from third party sites complete with details instruction how to unlock your phones. Thank you i hope my solution can help you.
Aug 27, 2011 | LG Vu CU920 Cellular Phone
I forgot my unlock code, and i would like to know if i can just master reset the phone?
yes you can do a master reset to restore it to factory but i would try a soft reset first. it will also do what you looking to do but it wont erase your data . i have included a full list of codes . try the master unlock code first.
Code Action
*7 Use to lock/unlock the mobile keys
19980722 Work as "Master key" to unlock the Motorola sets
*#06# To display the IMEI Number of the mobile
*#403# Press keys to get information about mobile manufacturing
*#301# Use to test the functions of the keys
*#303# Use to reset default language to English
*#300# Use to display the mobile software2.gif/hardware version
*#311 Use to reset the default code of mobile
*#402# Use to regulate the mobile display strength/intensity
*#304# Press keys to OFF the engineering mode
*#304*19980722# Press keys to ON the engineering mode
*#0000# Use to reset Motorola mobile default language
1234 Default Motorola mobile code
32*279*1*0*8 Use to verify the mobile model
#PROGRAM# Use to change the default banner of mobile
##33284 Use to run mobile in Debug mode
#02#* Use to display the mobile software version
*#42253646633#
Use to enable COM port
*#987*99#
Use to restore the Motorola factory settings
#32# Reset the mobile timers
###119#1# Use to make active the EFR mode for mobile
###119#0# Use to make deactivate the EFR mode for mobile
Nov 13, 2009 | Motorola Mobility i425 iDEN Cellular Phone
How can i get the tamper light to go out, so i can reset my alarm on the cooper menvier 9448+ alarm control panel
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Oct 06, 2009 | Kitchen Appliances - Others
I need the unlock code for my LG KS360 my imei is 355429027289554
1. Insert original sim card and turn phone on. 2. Enter 2945#*71001# 3. A menu will be displayed, select SIM Unlock. 4. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete.noway trytype 2945#*# and a engineering menu will appear select factory reset and you will reset all your unlock codes to 0000. http://www.pb4kn.co.uk/ks360_unlocking.htm
Jun 16, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Unlock code for LG TE365 (equivalent to LG KS360)
on the touch keypad "dial" 1809#*365# to enter Engineering Mode and select 4-Master Reset. You'll lose everything stored ON THE PHONE but will retain SIM card stuff and of course SDMicro stuff. The phone itself will be in out-0f-the-box condition
May 27, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I need a code to unlock keypad
May 26, 2009 | LG Rumor LX260 Cellular Phone
Unlock phone restricted
May 21, 2009 | Cell Phones
Kitchen Appliances - Others Logo
32 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
