Question about Takagi T K3 OS P OnDemand WaterHeat
No hot water
HOT WATER quit getting hot after cleaning filter - no red light or code light lit either
    Scholar:
  • 150 Answers
This indicates a reduced supply of water to the heater. Check water flow through the tap has not been reduced If so, check filter area
Posted on Apr 19, 2014
Why wont the pilot light on my hot water tank stay lit
there is no pilot- it is lit with a ignitor. If you have problems the unit needs a service cleaning of the flame sensor rods.
Aug 19, 2014 | Rheem Tankless Hot Water Heater...
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
Hi i have a power vent water heater model #-6g40pvw-40f. It go's into lock down mowed one light lit on vaction two more on A-and B is it the heating element or lighter mechanison thank you mike from...
Hello Mike,
Check gas pressure, burner parts need to be cleaned, check electrical outlet, hot surface igniter is bad
White Rodgers intellivent error code:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
Error code says: system in lockout, but you know that.
1) Low gas pressure, no gas to water heater: call gas company to check pressure
2) Hot surface igniter not positioned correctly: inspect and clean burner parts.
http://waterheatertimer.org/images/Reliance-hot-surface-ignite.jpg
3) Low voltage to water heater/ outlet has wrong polarity: Use circuit analyzer on electrical outlet to make sure polarity is correct
Typical power vent manual:
http://waterheatertimer.org/pdf/Reliance-40-50-power-vent.pdf
Cleaning water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
http://waterheatertimer.org/pdf/How-to-clean-combustion-chamber.pdf
Jun 19, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
No hot water
Well you didn't indicate what kind. Gas or electric? If it's electric, check for open fuses or circuit breaker. Could be bad element(S) If it is gas, is the pilot lit, if it doesn't have a standing pilot, is the ignitor getting red hot to light it. Need more model info to help
Jul 23, 2010 | Rheem Water Heaters
Scr2 titan water heater. No hot water. Both red
On the left side of the board there is a 10K 5Watt resistor that gets loose from the board because of overheat and it needs to core solder back with soldering iron.
Apr 28, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Sometimes water doesn't get hot.
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
Apr 20, 2010 | Rheem Tankless Hot Water Heater...
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Takagi T K3 OS P OnDemand WaterHeat Logo
110 people viewed this question
Top Takagi Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Takagi Water Heater Expert? Answer questions, earn points and help others
