Question about Hitachi C10FSH 10" Dual Bevel Slide Compound withLaser
Won't start after install of new trigger - Hitachi C10FSH 10" Dual Bevel Slide Compound withLaser
    Champion:
  • 304 Answers
Hi There
1; Is the power going to the switch first of all?
2; Do you get a reading of voltage coming out of the switch?
3; If 1 & 2 are ok check the inside of the housing and make sure the spring connections on the brush holders are ok and that the brushes slide through the brush holders smoothly.
4; Check continuity of both sides of the field.
5; Check power goes to the brush holders.
If you do not get any reading from the above that's where the problem lies.
Posted on Apr 17, 2014
Engine won't start
Sounds like the security system is triggered.
Jul 19, 2013 | 2000 Renault Laguna Estate
This is the izh 513m .177 rifle. It's brand new. I am not sure as of what to do and the hammer want budge and the trigger won't pull. The barrel has no tension and it won't go up like its supposed to.
This could be a factory safety that the hammer and trigger do not move while in the cocked position. The barrel may be locking down purposely. Look near the spring or in the path of the barrel where it folds back up and look for a release button. What do you see?
Jan 26, 2013 | Sport & Outdoor - Others
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Husqvarna blower #125BT won't fire over, has spark.
I have seen some issues with these machines shearing the flywheel key ( it is an alloy key part of the flywheel ) if the key has sheared it will knock the timing out and will now require a new flywheel.
Jul 07, 2012 | Garden
My Kia Sorento will start and then it won't start, replaced the fuel pump, but did not replace the fuel filter can this be the problem
When the fuel pump was replaced it is important that you install a new fuel filter as it is necessary to have a clean filtered fuel into the pump. Also check the injectors and the spark plugs.
If the spark intensity is low check the HT COILS and the ignition system triggers to the HT coils.
If spark is good then the fuel pressure and calibration must solve the issue.
Take help for consensus.
Thank you for using fixya.
Aug 09, 2011 | 2003 Kia Sorento
Hi i have a 019 l stihl won't start plug is fairly new with my glasses on i can't read the position's to start and have no manual
Not a great Stihl fan, however they usually have a single stop start, choke and half throttle lever, depress the throttle trigger and at the same time pull the lever fully uplet go of the throttle trigger which should now be lock up, this will engage the part throttle and choke, crank the machine until it fires once, then move the lever down one notch and crank again until it fires up.
May 30, 2011 | Garden
Never used weed wacker before I have a Echo SRM225 how do you start the darn. thing..? :) I have pulled and pulled and no I am not out of gas. :)
You need to put it in full choke. If it is in full choke and still won't start, try pulling the trigger a bit. once you have it started in full choke, back it down to half choke and hold down the trigger until it catches. Once it catches take the choke off entirely WITHOUT removing your finger from the trigger.
May 20, 2011 | Echo Garden
Hitachi C10FSH 10" Dual Bevel Slide Compound withLaser Logo
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
