Question about Miele Washing Machines
Washing machine says "water proof" and "fault" plus keep on beeping, the background is like draining but actually not, what can i do?
    Habit-Forming:
    New Friend:
  • 86 Answers
This machine has a leakage guard.
There is a leak somewhere internally. Remove top cover/plate and or front. And check for leakages.
Posted on Jun 19, 2014
SOURCE: Washing Machine keeps filling with water
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Posted on Aug 13, 2008
barkencoa
  • 3463 Answers
SOURCE: Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Posted on Jan 23, 2009
SOURCE: washing machine zanussi jet wash
unplug machine turn water off then take water pipe off machine,take machine outside and lay on its back,there is two moters up in the top right off machine looking in the bottom of machine, undo the three pipes and two/three srews take both pumps out undo three screws on the top pump split it and unblock then pup it all back.remember to right down wot you have done to pup it back right,it took me approx half hour to fix mine
Posted on Feb 28, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
My washer keeps saying err bush hw60_1460d
Oh boy I hope you're in the UK cuz that is a British unit here are the error code explanations
Error 1
Washing machine door lock has failed to operate or respond
The washing machine has detected an error with the door safety lock or interlock preventing operation.
Check door is closed and latched correctly
Check wiring
Check door lock
Error 2
Water drain time out or failure
The washing machine has failed to drain the water in a reasonable time, nominally in six minutes.
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
Error 3
Not drained in time allowed - washing machine fails to drain water
Error 4
Washing machine has detected problem with the wash heater
For this error code you need to check both the water heater or element and thermistor, the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
Check water heating element
Check heater for contunuity
Check thermistor or temperature sensor
Check the thermistor resistance
Check wiring to water heating element
Check connections to water heating element and temperature sensor
Error 5
Check water supply is on, clear and not frozen
Check the air chamber and pressure sensor hose for blockages
Check water inlet valve
Check wiring to water inlet valve
Check connections to water inlet valve
Check the main control PCB
Error 6
Motor heat protector error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit in relation to teh overheat protector within the motor itself.
Check motor connector block
Check motor carbon brushes where fitted
Check wiring
Check tacho connections
Check motor
Error 7
Motor error or failure
The washing machine has detected an error on the washing machine's main drive motor circuit but, like other errors cannot pimpoint he exact location or nature of the fault.
Check wiring
Check motor
Error 8
Washing machine has detected an overfill situation
This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
Check for overfoaming or over soaping
Check the air chamber and the pressure switch hose
Check water level sensor
Check wiring to water pressure sensor
Check connections to water level sensor
Check main electronic controller
UNb
Washing machine has detected an out of balance situation
This error code is caused by an imbalanced of incorrect load in the washing machine
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3629-bush-washing-machine-error-codes
Mar 13, 2018 | Washing Machines
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Washing machine beeps, doesn't run
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 08, 2014 | Kenmore HE2 Plus Front Load Washer
Ignis adl349/a seems to fill and drain ok but stops after 2/3 mins and beeps 4 times
What this actually signifies is that there is a problem with the spray arms; they are blocked, needs cleaning.
Then, check on the filters as well, its an uncommon problem, but once cleaned, run the machine on a hottest wash, hope it clears the problem.
Check inside for the hose (see if in place or off the top spray bar)to check whether water is going into the spray bars and spray arms work well. ----------
The 5 flashes indicate a spray. Pump fault, either blocked or motor fault.
Press and hold the start button until the light goes out.
Select a program and try the machine again.--------
This should help.keep updated.Thanks.Helpmech,.
Feb 16, 2011 | GE Built-In Dishwashera Oven
I have a Kenmore 110.4751 It will periodically beep while washing clothes. I don't find any error codes visible. I don't find any explanation in the manuals for this condition.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore he washer will not drain all the water also have code E20 flashing
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
