Question about Brother MFC-6890CDW Printer
Prints blue not black - Brother MFC-6890CDW Printer
PF Pro printing pale blue instead of black
you are printing composite black instead of pure black.
Still problem is the print head not getting all inks (may be air, or you didn't remove some seals on the inks/print head.
Nov 07, 2013 | MicroBoards Office Equipment & Supplies
Canon Pixma 5100, no black ink, but blue won't print? why?
Main Cartridge is black it is required for printing it is not possible to print black with other cartridge.
Jan 02, 2013 | Office Equipment & Supplies
I accidentally filled a 121 black cartridge with blue color yesterday. I have tried to remove the blue color so that to fill a black one but it has failed and when I print, it only print the blue color.I...
Did you remove all the blue ink from the cartridge? It is possible that there is still a small amount left. Just keep on printing until the blue ink runs out and the black ink will replace it.
Oct 27, 2011 | Office Equipment & Supplies
Why is my printer printing out blue ink and will not print out black ?
Most printers default to print in color, therefore it will try to mix blue with black to get the right tone in your print job. Try sending the print job as "Black & White" and it might let you print it that way. Give it a try. Take care and good luck.
Mar 10, 2011 | Office Equipment & Supplies
I have HP Deskjet D2466 Printer and when i want to print with color cartridge, the black color would be printed as blue color... My black cartridge was exhausted so i only can printed with color...
when the color cartridge has to make black, it uses all three colors. printing blue indicates that the color cart. is getting low on red and yellow. get a new black cart. and a new color, 'cause it' s coming due.
Let me know
May 18, 2010 | Office Equipment & Supplies
Won't print black and white, looks blue
Hi
HP uses a system for black that prints a base ie: Cyan / *blue then overprints it with black...
Sounds like you are either out of black or you have an ink clog?
If so... you need to use a print head cleaner like Magic Inkjet Flush you can get a kit on Ebay.
Good Luck!
Apr 09, 2008 | HP OfficeJet r40 InkJet Printer
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function CenterĀ® MFC-215C...
Brother MFC-6890CDW Printer Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
