Question about Various MFR 2002 Ford Windstar A/C Condenser
1999 ford windstar fuel pump reset button - Various MFR 2002 Ford Windstar A/C Condenser
Emergency fuel shut off valve location 1998 ford windstar and how do you reset it
The fuel shut off is a switch - inertia fuel cut off switch , it cut's electric power to the fuel pump . If it was tripped just push the button ! Located behind- driver side kick panel !
Aug 21, 2015 | 1998 Ford Windstar
How do you turn the fuel pump shut off button back on a 99 Ford windstar
  • The inertia fuel shutoff switch is located behind the driver side scuff panel. An access hole is in the scuff panel to access and reset the fuel shutoff switch.
NOTE: In the reset position, the button can be pressed an additional 1.59 mm (0.0625 inch) against a spring. This is a normal condition.
To reset the inertia fuel shutoff switch , press button on top of inertia fuel shutoff switch .
saailer
Apr 16, 2015 | 1999 Ford Windstar
1999 ford windstar fuel pump reset switch
That switch won't be open or a problem
Need to be in an accident to jar it
Check around the side kick panels where your
feet would be
Google the location
Easier to find the pump relay & test the entire circuit
at one location-- IF-- you had a wiring diagram
Aug 11, 2014 | 1999 Ford Windstar
Ford windstar fuel pump relay
Reset the inertial switch (collision safety switch), located inside a compartment accessible from the inside of the vehicle, near the driver side rear lights. There should be an extruded red button which you press in to reset.
Apr 07, 2014 | 1997 Ford Windstar
My 1997 ford windstar won't start put in new fuel pump
could be coil or possibly the crank sensor
Mar 22, 2014 | 2001 Ford Windstar
Is the fule reset button on a 1995 ford windstar suppost to up or down'
down to check tap with screwdriver it should click wit a spring sound. must b pressed down to engage fuel pump
Apr 03, 2012 | 1995 Ford Windstar
No power to fuel pump has new pump asy
have you checked the fuse and relay for fuel pump. if they are ok, it is in wiring to pump. check to see if ground to pump is not corroded. 1995-1998 Reset Button location---The fuel pump inertia switch for a 1998 Ford Windstar is located behind the trim panel by the driver's left foot by the hood release (according to the owners manual. good-luck!!
Aug 10, 2010 | 1996 Ford Windstar
I cant find the fuel reset button in the back right side of my 1999 ford windstar to see if it needs reset. IF I do find it what fuse can i check if its not the problem?
Fuel shut off switch is located in the back of the vehicle on right side where your jack is stored. You have to remove jack and pull out some plastic covers to expose fuel shut off switch.
First Check your fuel pressure on the fuel rail in the engine compartment. Could be your fuel pump malfunctioning.
Feb 19, 2010 | 1999 Ford Windstar
1999 Ford Windstar-Will Turn over but won't start?
fuel pressure regulator could hav failed-located by engine or the ignition module may not be workin-by dist area try not to be a parts replacer-buy a repair book
Jan 09, 2010 | 1999 Ford Windstar
Various MFR 2002 Ford Windstar A/C Condenser Logo
20 people viewed this question
Top Various MFR Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Various MFR Heating and Cooling Expert? Answer questions, earn points and help others
