My MCP6P-M2 Motherboard worked over 3 years fine. Now, after longer time? unused, the PC does NOT boot. Screen stays BLACK, NO beeps , CPU Fan runs, HDD-Drive seems to run (Red HDD-light after short time (Booting process ?) turns off. Insert of an Graphic board in PCI-E does not solve problem. What can be wrong with my Board ? Please help me!
Bad monitor none told but 2010 and older have CCFL lamps that 99% are all dead now, EOL>
test old monitor on other good PC, to see if monitor is bad
and see if the monitors OSD button is dead if is the monitor is dead.
power on mon, under15seconds hit menu and OSD must pop up.
that is 1 of 20 causes I can do 19 more and 19 more tests but I full stop here.
CCFL lamps die at 20000 hours, even 5 years old possible.
SOURCE: motherboard problems??
If all the peripherals are working in other machines then it sounds like the chipset or the bios itself would be suspect.
Did anyone Flash the bios with an upgrade?
I have a motherboard that the northbridge is affected. All components seem to work fine except no USB ports or CardBus work.
SOURCE: ghost floppy drive
No virus, the mb 's chipset is dying. Prepare for an imminent failure - backup all your data and save money for a new one.
Testimonial: " "
SOURCE: my computer has no display no beep. it blinks the
pleas help me!!! My computer has no display no beep.
it blinks the
Problem with the Biostar MCP6P-M2 Motherboard - v6.0,
