Question about LG LDF8072ST FulIntegrated Steam Dishwasher in Stainless Steel LDF8
Dishwasher displays and nE at the end of the cycle and all the lights are flashing!
Other than that problem it seems to clean the dishes, it used to be blank and not flash lights. I have to hit the power button to turn the lights off.
  • 489 Answers
SOURCE: LG dishwasher wont clean top rack dishes
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
Posted on Jun 08, 2008
  • 677 Answers
SOURCE: RESIDUE ON DISHES-NOT CLEANING WELL-DETERGENT NOT DISSOLVING-LONG CYCLES
the problem is not the dishwasher but the water that actually is going into it. the white, powder substance is because of hard water. there is a affordable product out there called the dishwasher filtration system. it will filter the water going into your dishwasher and solve the problem once and for all!!! it is affordable and easy to install. www.dishwasherfilter.com
Posted on Feb 09, 2009
  • 423 Answers
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Posted on Mar 29, 2009
  • 423 Answers
SOURCE: dishwasher wont dissolve tablets or was the dishes
Never use tablets or gels in a dishwasher, especially in a water conserving DW like and LG dishwasher.
Buy a box of Electrosol or Cascade powder -- not a cheap generic product. You will be amazed at the difference. Tell a friend.
Good Luck!
Posted on Apr 07, 2009
  • 384 Answers
SOURCE: LG Dishwasher redepositing debris back onto dishes
Have had a problem with our LG 5811 Dishwasher not operating.
I have found the Vent Hole Cover located inside the Door was not installed correctly. I used plumber putty between the plastic fitting and the inside face of the Door and turned the Cover fully to lock in place (vent hole is toward Door bottom). Water was leaking previously from this opening over the wires in the door.
Another problem was the lower Door Seal (under the Door) it was not installed correctly either. It was actually too long and would not seal against the bottom of the inclosure. Water was coming out and spraying the wires in the door. I had to remove the metal stiffener over the front of the Dishwasher to get to the Door Seal. I removed one end and reinstalled the seal. The Seal laid flat but was approximately 3/16" to long. I cut off the end with a sharp knife - seems to be the correct length now.
Posted on May 28, 2009
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Cycle seems never-ending
on the ECO 50 cycle dish washer will not stop. have had to switch it off, when try to restart it automatically goes back to the ECO 50 programme. Can you please help. The Serial No. is ADP 2440 WH.
Nov 24, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
LG LDF8072ST FulIntegrated Steam Dishwasher in Stainless Steel LDF8 Logo
66 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
