Question about Coffee Makers & Espresso Machines
Keurig rivo not puncturing
I have a keurig rivo and it has stopped puncturing the cups? Any thoughts?
  • 5 more comments
  • Nikki Jacobs
    Nikki Jacobs Feb 20, 2016
    My keurig rivo is not puncturing the pods
  • Anonymous Feb 21, 2016
    Nikki Did you look at lpfaff post 2 links tell what to do.
  • Bart Rasmussen
    Bart Rasmussen Feb 22, 2016
    I am having the same problem. Other articles are explaining other models, not the rive which takes the r-cup. I believe this one was forced when the used cup resivoir was full. There is a mechanism that might be replaceable for a fraction of the cost of a new one. But not having any luck finding a part number yet.
  • Patrick
    Patrick Apr 19, 2017
    For anyone else still trying to solve this like I was - the problem was that if you push the loading handle down too hard while the cup is stuck (like when the catch pan is full of used cups), it misaligns the handle with respect to the carriage. Just open it all the way, and apply firm pressure to keep opening the lever, and it will re-align it. It will feel like you're stretching it out, but don't worry.
  • Paige Johnson Apr 22, 2017
    This just happened to me this morning. There was a pod stuck and I tried pushing down on the pump really hard...not knowing a pod was stuck. This must have misaligned the handle. I did exactly what Patrick's instructions where above and it worked perfectly and fixed the problem. Thank you!
  • Anonymous Apr 24, 2017
    Patrick saved my life (no coffee = no life)!!!
  • Anonymous Aug 20, 2017
    Happened to me just as Paige wrote. I pushed the handle up slowly and bent it back into position. I was a bit afraid I was going to break it. I think I pushed a little too much because now the handle is not flush with the top of the machine when after I close it. Hint: don't push back all the way and test it until a cup punctures and the handle is flush with the top. Also empty the cup reservoir often enough!All in all the machine works just fine. I can live with the handle not flush when closed. Thanks Patrick.
    Top Expert:
  • 11,573 Answers
Just push the cup firmly down onto the lower needle before closing the "clamshell" and puncturing the lid of the K-cup also. Read the attached link, other people have this problem.
2nd link explains problem very well.
Preventative Measures How to Keep Your Keurig Brewing Cup Barista
Fix your Keurig imsolidstate
Posted on Feb 20, 2016
    Top Expert:
  • Coffee Maker... Master
  • 41,533 Answers
You possibly bought the wrong cups .many are too short
5 Suggested Answers
  • 12 Answers
SOURCE: My kreig brewer Model B40 give me only hot water
The seal is too thin. Install a faucet washer on the top needle above the factory seal. Remove the factory seal (slides off the needle). Install the faucet washer and replace the factory seal. My machine leaked all over until I did this. Works Great!
Posted on Mar 04, 2010
cmccune04
  • 213 Answers
SOURCE: I need to find replace for internal chamber on Keurig
Go to http://www.Igotsweetdeals.com for all keurig replacement parts!
Posted on May 20, 2010
heatman101
  • 43501 Answers
SOURCE: Our single cup Keurig is
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Mar 21, 2011
heatman101
  • 43501 Answers
SOURCE: I am looking for a
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Posted on Sep 22, 2011
Keurig Rivo wont puncture cup
make sure the plunger is in place both on top and bottom
Nov 29, 2015 | Keurig Rivo R500 Brewer
When I use a Kcup NOT made by Keurig, in my Mr. Coffee, I get only water. No punch on bottom of K-cup.
Call Keurig @ 1 (866) 901-2739. The Companies to most of your products, are generally very good in helping you with issues. Best regards!
Aug 24, 2014 | Mr. Coffee BVMC-KG5 Single Serve Coffee...
Coffee overflows and grounds sit on top of pod
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Apr 28, 2010 | Keurig B60 Coffee Maker
Our K Cup holder broke.
your talking about the k cup holder, the black funnel part, this website sells all kinds of keurig parts check it out hope it helps
http://stores.ilikenew.com
Dec 30, 2009 | Keurig B60 Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Coffee Makers & Espresso Machines Logo
2,971 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
