Question about Sony Audio Players & Recorders
Tape slow speed
I found this cassette player in my grandmas garage, and the speed is really slow, i'm thinking its the motor.
3 Suggested Answers
  • 11 Answers
SOURCE: Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Posted on Apr 03, 2009
wwga
  • 106 Answers
SOURCE: Walkman Cassette player playing slowly
the belt is rot.
Posted on Mar 22, 2012
Marantz Cassette Deck Plays Tapes Slightly Too Fast
The speed should be adjustable but the common practice is to use a frequency counter and test tape or test tape and wow and flutter meter. I look at this from a Technician's point of view as I have been fixing units for 45 years so far. Once the motor speed control is found it does not take too long. Sometime it take more time taking the cover off.
Jan 31, 2014 | Marantz Audio Players & Recorders
New tape playing too fast. What do I do to slow it to normal speed?
You have to replace the IC 601, probably burns because of some passive components that must be replaced. "Doctor.walkman @ gmail.com"
Nov 21, 2010 | Sony Walkman WM-D6C Personal Cassette...
I would like to make this work again.I have cleaned the rollers with alcohol. When playing a tape the sound starts to warble as the speed varies, then the speed slows and it stops. It is plugged in. Is...
Il rimedio c'?, ma dovrei esaminarlo personalmente. La mia email " doctor.walkman@gmail.com " The remedy is there, but I consider it personally. My email "doctor.walkman @ gmail.com"
Nov 15, 2010 | Sony Walkman WM-D6C Personal Cassette...
Some of my old cassett tapes slow down & speed ''wobbles'' when playing. Is there any way to fix this?
The only thing you can do is take the tape out of the cassette and place it in a modern cassette case. Just buy new blank tapes and discard the new tape inside. If that doesn't work and it's not your player causing the problem then it's due to the tape itself.
Apr 04, 2009 | Audio Players & Recorders
Tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Mar 24, 2009 | Sony Walkman WM-FX290 Personal Cassette...
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
All cassette play too fast
I think that the rubber wheel pushing on the tape and controlling the speed is stuck somewhere and this preventing him to stay on the tape and control its speed
Daniel
https://www.rylwy.com/carbon-antenna
Dec 24, 2017 | GPX HMTU3234 Shelf System
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
Speed problem - logic chip?
see if two units share the same motor, there will always be a trimmer to adjust the speed, look for it and adjust to desired speed. if you haven't look for the belt, try to check.
May 16, 2007 | Kenwood CT-203 Cassette Player Single Dual...
Cassette Player
Motor speed needs to be regulated by PWM. Reducing the current (with a resistor) actually lowers the torque - which, with a given load, does result in reduced speed - however, different length tapes (60min vs 90min), as well as different quality, and even current position in the tape, will change the load and hence the speed. You need to regulate the speed via PWM. It's sometimes done on a small board built into the motor, in which case you'd have a round hole into which you could insert an INSULATED screwdriver (tiny flathead wrapped most of the way in electrical tape works). It may be done on the main board, in which case you could find a pot conveniently labeled "motor speed", or perhaps "pulse width" or "pwm" or something to that effect. Find it, mark its current position just in case, and turn it to see if it gets the effect you're after. And there are some tape decks in the world with no speed adjust - they are designed with a specific speed motor and the sizes of the wheels and gears are calculated for that speed. Also there may be a mechanical fault/malfunction causing the speed problem. An initial check and thorough cleaning of the capstan and pinch roller should be done. If there is a buildup of tape oxide or a piece of a broken tape wrapped around the capstan, the tape travel will be too fast (do to the effective increase in capstan shaft diameter). If the pinch roller isn't fully engaging, the tape can be getting pulled onto the takeup spool at a speed faster than the capstan control. A different source of trouble might be a slip clutch (possibly an idler/clutch assembly)which is binding, or otherwise not functioning the way it should. Another type of motor doesn't have it's speed controlled by an internal or external voltage.. instead, the motor has an internal centrifugal speed controller. This type of motor can be found on older tape decks, and might not have been utilized more recently. Good luck
Mar 07, 2006 | GPX HMTU3234 Shelf System
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
