Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
-F1- is showing on panel
How do I clear -F1- and stop the beeping
  • 4,889 Answers
F1 ERROR IS A KEYS STUCK ERROR...If you are not technically sound i advice that you get it replaced by a technician..They keypad is not very expensive..If you want to try doing it yourself then let me know..
Posted on Nov 02, 2007
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
Jenn-air Model S176 shows a f1 fault.....will not stop BEEPing......oven and burners work
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 08, 2011 | Kitchen Ranges
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
My oven beeped and showed F1 in the middle of the night clear off made it stop what is F1 and why did it the alarm go off?
The manufacture says it is a bad ERC (Electronic Range Control). This is the electronics behind the clock that showed the F1 code.
I would suspect there was either a power surge of some sorts that fooled the control into thinking there was an error, or the control is beginning to go out.
May 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Gas range beeps non stop and the panel shows F1
Hi bobctsai,
F1 error code description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Apr 23, 2010 | Magic Chef 31000 Gas Kitchen Range
Help our frigidare double oven is locked and we cannot get the chicken out....it keeps beeping and showing an f1 symbol
Press Clear/Off to stop the beeping... then press clear/off again. If it doesn't unlock - wait about 15 minutes for it to cool down.
The F1 error means the EOC (Electronic Oven Control) board has a failure - and thought there was a run-away temperature condition.
It should allow itself to unlock after a few minutes of cool-down.
For additional help in finding a replacement part - a Model # will be required.
Thanks for using FixYa!!
Jun 26, 2009 | Frigidaire Ovens
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
120 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
