Question about Samsung Televison & Video
Small whit flakes in screens whynowflake drop sign
    Sergeant:
  • 264 Answers
Sounds like you have pixels going out in the screen itself just like on a cell phone.
Posted on Apr 17, 2014
I haveemersonlcd40"modlc401em2f and when turn on the screen looks redand whit vertical lines in the middlewhat wrong but l can see the picture appreciate help me thank you
A picture would be great but what you are describing sounds like a impacted screen or a defective screen. If i have been of help to you please sign my guestbook
http://www.back2lifeelectronics.com/Guestbook.php
Jun 10, 2014 | Televison & Video
Tip
What is the main process introduction of sunflower oil machine?
Main process introduction of sunflower oil machine
??Cleaning--Destoning--Crushing--Softening--Cooking--Pressing
Sunfloewr oil press machine cleaning part: In order to obtain high effective
cleaning, ensure good work condition and production stability, high efficient Cleaning
screen was used in the process to remove big and small impurity.
Sunfloewr oil press machine destoning part: Used to remove impurities such as the proportion of larger stones after cleaning.
Sunfloewr oil press machine crushing party: In order to ensure flaking effect, sunflower is generally broken up uniformly 6~8 flakes and water distribute uniformly during softening, and flakes is thin and burliness.
Sunfloewr oil press machine softening part: By adjusting the temperature and
moisture, making the oil suitable elastic-plastic, reducing the degree of powder when
flaking and sticking phenomenon, to ensure the quality of embryo piece.
Sunfloewr oil press machine flaking part: Using mechanical power, there will be a
particulate oilseeds rolled into a sheet process.Oilseeds' cell wall damaged and shorten the oil discharged from the oilseeds.
Sunfloewr oil press machine cooking part: The purpose refers to steamed fried green body through moist, heating, steam embryo, embryo fry and other treatment, the process of becoming mature embryos.To increase the permeability of the cell wall , make the oil easy flow out.
Sunflower oil press machine
on Apr 25, 2016 | Miscellaneous
My screen went black
this is happens whit i4 i4s after you drop the phone . you have to solutions . one if you know a technician hes gonna put back the flex of LCD witch removed after the drop its very easy or gonna change LCD & digitizer .
if your phone is not 4 or 4s you have to change the lcd digityzer for sure .
Mar 02, 2014 | Apple iPhone 5c
I don't have a sign out option button
Go to the top right of the screen there you will find your email name followed by a drop down arrow. Click on the arrow it will bring up a small box containing the sign out button.
M
Jul 24, 2012 | gmail.com Computers & Internet
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
Fuser error
hallo
if you open the door you will se the fuserunit.
this is black and yellow.
on top of it is a small cover whit one screw.
under it is a thermostate loos it test it whit a maltimeter. must be closet not open.
if it is open drop it. if you shake it it must sound like samthing is loos in it.
or replace it. it sould work.
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Mar 04, 2009 | Mr. Coffee ECM20 Espresso Machine
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
Transmission dont work on D
I had the same problem I found the Transmission had water in it . the lady had a front end accident and cooler leaked. She had it serviced but too late . I got a great deal from her open up the transmission found the clutches flaked off.
Aug 18, 2008 | 1994 Isuzu Trooper
My cell phone
Open it up and check for fuses that don't work well.
Nov 01, 2007 | Motorola Mobility V710
Televison & Video Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
