Question about Whirlpool Duet GHW9150P Front Load Washer
Fabric softener won't dispense
The fabric softener won't dispense. I have taken the whole assembly out and cleaned it...still won't work. Any other ideas?
  • dianeb62 Jun 24, 2009
    Yes, I did try that. Thanks for the input though! I appreciate it. :-)
    Problem Solver:
  • 5 Answers
Have you tried thinning the softener with water? It's what I used to do on my older washer, it wasn't the new Duet, but it seemed to help. Hope that helps. (PS I don't use softener anymore as I have developed a terrible skin allergy to these newer longer scented softeners! )
Posted on Jun 20, 2009
  • knitr54 Jun 24, 2009
    Sorry, it didn't help. One other thing that I have used for years to soften clothes( and I just read this tip online in a how to save money tip when doing laundry) is plain old white vinegar. I have used it for years, maybe running some of that in the softener dispenser might unclog it.
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener dispensor does not empty
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softener dispenser water valve. Did you hear the solenoid hum? If so we will now need to turn on the Cold Water Inlet Valve and see if water flows to the dispenser.
Now press the Spin Only key this will turn on the Cold Water inlet valve after 5 seconds press the Off key. The washer will unlock. Check to see if water did flow to the fabric dispenser reservoir. If you heard the Fabric dispenser valve hum then most likely 120VAC was applied to the solenoid. If water did not flow then the Fabric dispenser valve is stuck closed if you heard it hum.
The Bleach/Fabric dispenser water valve is an assembly and is not repairable you have to replace.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Fabric dispenser solenoid.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price try appliancezone.com…
You can remove the Fabric Softner to clean see page 33 of the Service Manual…Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The fabric softener will not dispense into the machine
Will be dirt in the drawer, take it out give it a good clean make sre the small tube is cleaned too if it has one/.
Sep 27, 2009 | LG WM-1485FHD Front Load Washer
I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Jul 30, 2009 | Whirlpool WTW6400SW Top Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
593 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
