Question about Yellow jacket 95760 RecoverXLT Refrigerant Recovery Machine
Upon startup unit trips breaker and shuts off
Looked in the manual it said do restart procedure, which I did and it still trips the breaker upon start up shutting off the unit. This is a new unit never used. What is the issue? What should I try?
    Sergeant:
  • 264 Answers
Do you have connections completely on and open it sounds like it I dead heading and kicking the safety off. I would double check all connections and make sure the valves are open. Not trying to be insulting just what it sounds like. I hope that's all it is just a simple mistake.
Posted on Apr 17, 2014
  • 1 more comment
  • Rick Hale
    Rick Hale Apr 17, 2014
    connections are tight and everything open
  • Rick Hale
    other ideas?
  • Peter
    Peter Apr 18, 2014
    Hi Rick, sorry to hear you are still having troublle with it. The only other thing I could think of would be when they built the machine that the motoe was wired incorrectly or a wire got pinched and is shorting out. I would use a multi meter and put it on OHMs setting then touch one probe to one of the prongs of the power plug and the other to a metal part if any is visible to see if there is continuity then try the other prong on the plug, One is power and the other would be neutral, I wouldn't worry about the ground prong on the plug but if there is continuity on one of the others it will be shorted inside. I know you need this to make money but if you go into it too much instead of returning it for another they may not honor the warranty. I assumed you already tried another outlet just to make sure it wasn't the outlet. After al this and you've talked to Yellow Jacket themselves with no results I'd send it back for another. You paid good money for the unit and shouldn't have to waste your time troubleshooting a new unit. Good luck and let me kw the outcome please.
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Nov 18, 2013 | Ecoquest Living Air Classic Air Purifier
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Jun 13, 2011 | Rainbow Rainmate Air Purifier
Have Kenmore 85501 Air Cleaner. Unit will not restart after power failure. Send unit to Sears Service Center but they declined to fix unit. Tried to hold timer and function buttons for 5 seconds and...
Turn the Master ON/ OFF Switch to OFF and unplug the unit. Wait 12-15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set your controls. The 12-15 minute timeout should have allowed the unit to reset itself.
Apr 16, 2011 | Kenmore EnviroSense 85501 Air Purifier
My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?
Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Apr 04, 2011 | Sharper Image Ionic Breeze 3.0 Air...
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
Mar 29, 2011 | Honeywell 17000 Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
I have this air conditioning unit where suddenly stops functioning and no power on the indicator. i have thecked the breaker and it is fine and ON with a three phase supply. I've checked the condenser at...
Hi, I will see if I can give you some idea of what may be happening. I work on these on a day to day basis. So, you have a split system with the condensing unit on the roof, or a package unit on the roof? Sounds to me it is the first one.So, you are telling me that the power supply at breaker below is OK, but you should have a power box at the condenser on the roof. When you reset power to the condenser, that's when you here this blast sound? To me from just hearing what you are saying , it would be the sound of the compressor trying to start up, and it has a internal problem making this noise. Tell me, when it makes this noise, does it trip the breaker again? If so, it is definatley the compressor. You can prove this if you are inclined to do this, is to find the 3 different wires going to compressor, and make sure power is off 1st. Disconnect them at the Contactor or remove the plastc cover from compressor and write down which wire goes to each terminal.Tape the ends so they dont touch metal. Turn the condenser back on and see if this blast is gone. If so, the compressor is dead and you will need a new one.You say you have 3 phase power? This is unusuall for a residential unit, 3 phase units are for comercial unit power. They dont use starting componants like Run or start caps because they have enough power to do the job.3 phase would have 3 hot legs of equal voltage unless it was the older 3 phase which will have a stinger leg with higher voltage then the 2 other legs.Maybe this is a commercial a/c. Also, the compressor is reversable on a 3 phase unit by moving 2 of the 3 wires on the load side of the box, like T-2 and T-3. If these are switched if the compressor is locked up, sometimes you can get lucky and break it loose.Please don't do this, I am just explaining to you a little about 3 phase. Try this so you can elimanate the compressor. The only other thing it could be, if this is a gas pack and you are starting the heat, you can be getting blow back premature combustion? But I don't think this is what you have. It has to be the compressor.So, lets prove it by taking it out of the circuit. all should hold and no noise.Still, a faulty compressor is not a good thing. Let me no. Best of Luck and safety first.
Sincerely,
Shastalaker7
Nov 25, 2009 | Air Purifiers
This air purifier has not reduced my allergy symptoms.
You are a ***** and need to get outside more ;-)
Dec 03, 2008 | Ionic Pro TURBO Air Purifier
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Yellow jacket 95760 RecoverXLT Refrigerant Recovery Machine Logo
97 people viewed this question
Top Yellow jacket Air Purifiers Experts
Are you a Yellow jacket Air Purifier Expert? Answer questions, earn points and help others
