Question about Cuisinart CBK-200 Bread Maker
Cuisinart 200c turns on but paddle wont move
Paddel seems seized belt and motor are working
  • Terry ades
    Terry ades Apr 17, 2014
    The paddle and bread pan need to be replaced. This will solve the problem.
  • patrolcats Apr 23, 2014
    I simply bent (outward slightly) the bread pan holders inside the bread maker. This held the bread maker down more securely, allowing the motorized shaft to better engage the paddle. Voila! No more slipping of the paddle!
2 Suggested Answers
SOURCE: My bread maker Cuisinart CBK
I went to a service.
Posted on Oct 04, 2008
When i put in the baking pan, the kneading blade does not move
If the motor is working and the paddle doesn't move, take the pan out and see if the drive shaft is turning. If not then it's probably a broken belt. If it is then check for a seized shaft in the pan.
Mar 29, 2015 | Sunbeam 5891 Bread Maker
How do i tighten the belt for the paddle?
It's a timing belt, so it isn't supposed to stretch. There is no tension adjustment that I can see. Are the 4 motor screws in place and tight? Is either the motor or the kneading paddle drive shaft turning in its drive wheel? Is the frame bent and causing the belt to walk off one of the pullies? Another problem can be that the bearing in the pan won't turn, then you'll get a loud bump as the drive mechanism tries to turn the paddle in the pan. If this happens, try to free up the paddle by hand so it turns. Then when you bake, always put the oil in the recipe in first and rotate the paddle a few turns to work the oil into the pan bearing. If the oil gets in first, it will keep the water out and the pan will work fine. I've been getting away with this approach for hundreds of loaves.
Jul 02, 2014 | Cuisinart CBK-200 Bread Maker
Cuisinart cbk-200 bread pan paddle does not turn.
Your drive belt is probably broken or has slipped off. Unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. Most bread machines have a removable panel. Hopefully yours is one of those. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt. If your belt has a number code on it I will need that. It will look something like this: STS 60 S3M471 If it has no code on it I still may be able to figure out the belt you need. Again, reach me at my website: breadmachineshelp.com
Mar 18, 2013 | Cuisinart CBK-200 Bread Maker
Motor runs paddle does not move
Your drive belt is probably broken or has slipped off. unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt.
Jan 06, 2013 | Cuisinart CBK-200 Bread Maker
The paddle in my new 1.5 L ice cream maker is not turning - is this normal?
Hello Maryo803,
It is not normal for the paddle not to move in these units. First we have to determine weather the paddle is striped or the gear is stripped. At the bottom of the paddle there is a hole that attaches to the turning gear on the machine. Look and see if it still matches the sprocket in the bottom of the ice cream maker. If it does not still match I would suggest buying a new paddle. You can purchase a new paddle from Cuisinart for $8.00 and here is a link to the page. http://www.cuisinart.com/parts/ice_cream/ice-20.html
However, if it is not the paddle please post back to this thread and I will see if it is worth changing out the bottom gear.
Thank you for choosing FIxYa.com
Justin
Mar 11, 2011 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Kneeding seems to jam frequently
Hi, Take the bread pan and paddle out of the machine and see if the paddle spins freely by hand. If it sticks then the sealed bearing is failing. If everything is good here, check the tension on the belt pulley. The belt may be too loose to spin the paddle freely under load. Belt and motor is inside the base of the machine. Good Luck..Hank
Mar 13, 2010 | Cuisinart CBK-200 Bread Maker
Paddle does not move. Machine is about two years old.
sometimes the brushes take a set when unused.. Unplug the motor. Without using rnough pressure yo break anything, try turning the motor by hand using the paddle. You will be trying to turn the motor through ithe gesrs so use slow steady moderate pressure. This does work. as long as you watch what you are doing wiyh yhe force you apply. Good Luck. and enjoy the ice cream
Sep 07, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Even though I pour the ingredients into the ice cream maker while the motor is on and the bowl is turning, it seems to freeze too fast and then the inner piece won't turn. When the inner piece stops...
You have exactly the opposite problem of most users - for you, I would reccomend taking the freezer bowl out of the freezer a bit earlier than usual, slightly warming the initial ice cream ingredients, or raising the temperature of your freezer. To an extent, you will always get that rim directly on the sides of the freezer bowl, but my rim never extends so far out that it stops either of my two Cuisinart ice cream makers (or their paddles/bowls) from spinning.
Aug 07, 2009 | Cuisinart Ice Cream Makers
My wii wont turn on but my paddels work fine
If by "paddles" you mean wii remotes or wiimotes then the wii is turned on and it sounds like you may have your video cable hooked up wrong.
Mar 16, 2009 | Nintendo Wii Console
Need A Replacement Paddle
I have 2 breadmachines 1- K6745 & 1-welbilt ABM2H60 model. The paddel for the latter should work in the k6745. The female shaft of paddel is a little short but should do the trick, I think. Both machines have the normal type loaf pan, and the paddel did fit onto the shaft, so maybe looking at another machine w/ same style of pan will work also.
I really enjoy my K6745 but in a move I lost my manual could you e-mail a copy to me?
Aug 27, 2007 | Regal Ware K6745S Kitchen Pro Bread Maker
Cuisinart CBK-200 Bread Maker Logo
82 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
