Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover steamvac spinscrub clean water tank lid stuck
Lid for clean water tank is stuck
5 Suggested Answers
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
  • 97 Answers
SOURCE: Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Posted on Jul 19, 2009
  • 14 Answers
SOURCE: Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Posted on Sep 11, 2009
SOURCE: My Hoover SteamVac Agility's dirty water tank isn't filling up
CHECK THE RETURN HOSE ...IT'S PROBABLY SPLIT.
Posted on Sep 29, 2009
Testimonial: "The return hose was split, but it would have been nice if the advice also explained how to check for the split in the return hose. Thanks though!"
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Can't get lid off of water and shampoo tank of a hoover steam vac
You can get the tank off the machine correct? Pull down on the black handle.
The lid is the black circular cap on top of the tank. It only moves a bout a quarter of a turn then pulls straight up. If it's still stuck run it under hot water to loosen up any residue buildup.
Aug 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I don't know where to put the water?
The clean water goes on top. You want to check your bottom tank and make sure the lid is not lose.
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac spin brush puts out water, won't pull it back up. Checked all parts, no cracks. Cleaned filter.
Check for the front panel duct located on the lower tank front. this is the part you need to remove to attach the hose. also check to make sure the lid is on and secure on the lower tank. remove the lower tank and look on top of the motor cover toward the left front corner you should see a round black gasket on a pipe. if not there, this will cause poor suction.
Jan 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAMVAC CLEAN SURGE
The tank lid is not securely shut. Or you have stopped up machine full of carpet lint and dirt. Take it apart starting with the lid and make sure its locked down good if that isnt it ..clean out your machine.
Oct 18, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Model F6056-900 SteamVac/SpinScrub. Indicator light and high pitch suction noise indicates that dirty water tank is full. However, water level indicator (yellow bobbing plastic thing) is...
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
May 26, 2008 | Hoover Vacuums
Not sucking up dirty water
The F5914 has a lid that must be engaged with the tank in order for the suction to reach the floor. Gently lift the front of the lid on the tank and if it lifts up, you haven't engaged the two tabs on the tank into the lid. Remove the lid and make sure the tabs on the tank fit into the grooves on the lid and snap it closed. This should solve your problem. Also, make sure that the removable duct in the front of the tank is in place. It is removed when the hose is used, but must be replaced when the machine is used on the carpet.
Feb 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Jan 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Won't suck up the water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid for the dirty water tank is not locked down all the way around.
Nov 14, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac 5863-900
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter, or the lid for the dirty water tank is not locked down on th e tank.
Aug 28, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
51 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
