Question about Lexmark Z617 InkJet Photo Printer
Improper paper intake
Well, the page of paper is either not been intaken in order for the document to be printed, either the document that I receive, is printed diagonally on the paper used. What can I do for this problem?
  • sophkara Jun 18, 2009
    sophkara
    Thanks anyway, it ended to be a rather embarassing problem. Just a few pieces of paper had fallen into the printer...
Reinstall the printer driver and see if the problem still persists the visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
Canon Fax-L700
There is a cable that runs from the scanner to the processor. Looking from the front, its on the left side of the machine, on the back, it is a fairly large connector.
Unscrew the two thumb screws, then unplug it and plug it back in with the machine ON.
It will force it into a reset and may boot.
The problem is caused by a software glitch .
Check the tray settings and ensure that paper size guides are set to the appropriate paper size, then power off/power on the machine.
SAM ANDERSON
Sep 20, 2008 | Canon FAX-L800 Plain Paper Laser
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
When printing paper jams after the second page.
Clean the pickup roller with a damp cloth, check whether transfer roller under toner cartrige rotates freely. Check if the size of the loaded paper is the same of the document in the application, i.e. if you print on A4, your document should be set to A4. Sometimes you may receive a document by email with different paper format from what you expect. Reformat the document as setting the page size to your loaded in the printer one.
Jun 14, 2010 | HP LaserJet 3330 All-In-One Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
Open Questions:
See all Lexmark Z617 InkJet Photo Printer Questions
Lexmark Z617 InkJet Photo Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
