Question about Sylvania CL572b (Black) 15 in.
No Screen display
When the monitor is connected to the computer and plugged in, an orange light is on the monitor but it never goes green and the screen never shows any type of light. I have already changed out cords that I know that work.
2 Suggested Answers
  • 22 Answers
check when you plug it in all the copper wires are placed correctly and if that dosnt work while it is plugged wiggle it a bit and if that doesnt work wiggle it more
Posted on Jun 14, 2009
  • 14 Answers
SOURCE: I was given a 17"
yes. you can replace them with replacement cable for monitors. Just go to your nearest computer store and ask for replacement cables provided with the Brand Name of the monitor.
Posted on Aug 31, 2010
0 characters
1 Points
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 14, 2014 | Soyo Computer Monitors
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computer Monitors
When computer off monitor displays orange light.when i turn computer on green light briefly on than goes out. Monitor remains black'
This is not always a problem with the monitor. It could also be caused by a faulty display card in your computer. Try plugging your monitor into a working computer to determine where the problem lies.
Best wishes,
Jun 08, 2010 | Computer Monitors
Monitor will not turn on? westinghouse model L2046NV black screen will not turn on what should I do?
Do you see an orange light on the monitor anywhere? Usually the light turns green when the monitor comes on, but its orange when in "standby" mode. If your monitor is plugged in and you get an orange light, that usually means that your video card has gone out on your computer. When your video card goes out, the monitor doesn't receive a signal from your computer, so it doesn't know it is suppose to turn on. So if this is the case, you need to replace the video card on your computer
If your monitor doesn't turn on whatsoever, and everything is plugged in correctly, then you need to get a new monitor or send this one back to the manufacturer for a defective replacement.
Hope this helps! :)
May 03, 2010 | Westinghouse L2046NV Monitor
Plug in, press power, green light flickers once per second after a while goes to once per two seconds. then on screen comes up saying " no signal". then it goes ( according to the now orange light} to...
It sounds to me like your computer is not sending a signal to the monitor. If you switch monitors (borrow one if you don't have one) and the results are the same, I would look for the problem in your computer. Assuming you never see anything on the monitor when starting up the computer, the video card is suspect.
Of course, you need to check the cable connections and see if the video card (if an add-on card) is tight in the slot in the motherboard.
Mar 23, 2010 | Gateway FPD2275W LCD Monitor
The monitor starts up displaying no signal
This means that the monitor is not receiving a video signal from the computer. When it doesn't receive a signal, it goes to sleep. You should check to make sure that the video cable is tightly connected, and also, if you have another monitor around, connect the other monitor to the computer and see if it works. It's possible that your monitor has malfunctioned.
Mar 03, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
The sreen is black, and the monitor light is orange
This usually indicates an input problem. There are number of things to check:
Make sure the screen is plugged into a working output on the video card - if you can, test the video with a different screen.
Try a different cable; Swap for the same type of cable, or, if available, use a different output method(Such as HDMI).
If using an adapter on the cable, try using a different adapter.
Test the cable on a different display, if possible.
Ultimately, if the video card, cable, and connector are all working, or the display is still not, its likely a bad input board within the display - if you're savvy and have some time to kill, replacement boards cost between 20-70 bucks on ebay.
Feb 10, 2009 | NEC-Mitsubishi Nec Display Solutions...
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Sylvania CL572b (Black) 15 in. Logo
27 people viewed this question
Top Sylvania Computer Monitors Experts
micky dee
Are you a Sylvania Computer Monitor Expert? Answer questions, earn points and help others
